49-905 Mica Disease-FOUND IT!
Threads: 113
City: The Villages
After finishing (or so I thought) my 49-905, It has now started to make a crackling noise on AM only that sounds like the dreaded Mica disease. From the schematic I don't see any mica caps inside the AM IF cans. Any ideas?
http://www.nostalgiaair.org/PagesByModel...013674.pdf
Eric
The Villages, FL
(This post was last modified: 03-15-2014, 04:33 PM by Eric Adams.)
Threads: 554
City: Jackson, NJ
C301, 302, 304 and such - gotta be micas.
Threads: 113
City: The Villages
Thanks Morzh, I'll check them out.
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
Eric, the problem is that the caps are integrated into the plastic base insulator of the transformer. They are not separately replaceable caps but more like the compression trimmers found in older style IF's. Just silver coated sheets of mica riveted to the terminals. As the plastic ages it compresses and contact is lost between the silver and the terminals.
Threads: 113
City: The Villages
Morzh, are you saying that there ARE micas inside of those IF cans?
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
They are part of the base insulator that the terminals exit from.
Threads: 113
City: The Villages
So, short of replacing the IF can is there anything that can be done?
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
Years ago I fixed one of these, by drilling out the rivet, removing the mica sheets and replacing the caps with external silver micas. It was a lot of work but it did solve the problem. I know of no other way, because any IF transformers of this type construction have or will have the problem in the future.
I believe they are referred to as K-tran IF transformers. Do a Google search and see if anyone has better solutions.
This is what they look like inside:
[Image: http://i132.photobucket.com/albums/q18/b...aps/k1.jpg]
(This post was last modified: 03-14-2014, 02:35 PM by Mondial.)
Threads: 113
City: The Villages
Well, it looks like it is possible to repair. I do have some other cans laying around I'll swap them first and see what happens. Could the noise be from one of the mica caps in the radio or is it most likely the cans?
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
If the noise is only on AM, then its probably one of the transformers. Of course it also could be a bad resistor, connection or loose tube socket, etc, but I assume you already checked the other possibilities.
If you wiggle the IF transformer and the noise changes or gets worse, then that pretty much confirms that its the problem.
Threads: 554
City: Jackson, NJ
I saw an article just about 3 or so weeks ago, a guy wrote how he deals with SMD, I think he was working with some Transoceanic.
Just look up the Silver Mica Disease on the net, you will find it.
Threads: 113
City: The Villages
I got it guys! I replaced the 2nd IF can with an exact replacement and the noise is gone.
I'm glad I had a replacement. I wasn't looking forward to digging in to replace the mica.
Once again the greatest radio forum on the 'net comes through.
Thanks again, Morzh and Mondial.
Eric
The Villages, FL
Threads: 113
City: The Villages
I think this is what you're talking about. It is really helpful.
http://www.ppinyot.com/if_transformers.htm
Eric
The Villages, FL
Threads: 554
City: Jackson, NJ
Threads: 2
City: St. Charles, MO
Eric, don't throw that old can away. It is one of the easier ones to cut out the old mica and place new caps on the outside. Save it you may need it. Of all the cans that I repair, that type was pretty easy to get a repair style figured for it.
Don
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit. That would rem...alangard — 09:30 PM |
Tim
Well...a chassis is metal. Magnetic or not, it does not matter.
A transformer has some hum to it. It is natural....morzh — 08:40 PM |
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM |
Shadow Meter Bulb
Ross
I am not sure what current limiting effect the incandescent provides.
They are two different parts of the sch...morzh — 08:31 PM |
12' Philco
Bob
Thanks for that photo.
I have been looking for it, and I cannot find anythinmg on the web.
I forgot it was here...morzh — 08:29 PM |
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55.
I ...georgetownjohn — 07:31 PM |
12' Philco
There was also this Philco!
klondike98 — 07:25 PM |
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM |
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM |
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo
This is something alright. I'm go...RodB — 06:26 PM |
