Threads: 64
City: Northbrook, IL
I have 6AD6G indicator, which more often than not stays off, occasionally comes on, pretty dim in appearance, but when "on", operates normally and sensitive to the strong station.There is no loose connections.Shows 230 DC at the pin #5 (B+) instead of 180, but this 50v difference is across the board on all tubes- possibly from using 47 and 23uF caps instead of 40 and 20(?)
All other voltage readings are within norm.And I do not have the tube tester.
Time for the tube replacement? Thanks.
Threads: 554
City: Jackson, NJ
http://www.ebay.com/itm/Pair-of-NOS-NIB-...3f32cd0d91
If no one bids, get them.
Meantime, is the a socket that has a resistor inside or something? Have you checked?
Threads: 64
No, no resistors, just straight wire connections.
Threads: 554
City: Jackson, NJ
If you are sure you have your filament current (can you see the filament glow when the tube is dark?) and your anodes (you do not have to have grid to have it glow) voltages and it is intermittent then it could be a bad tube with some intermittent separation inside.
Of course you have to exclude the possibility of bad socket connections etc.
Threads: 40
City: Lehighton
State, Province, Country: PA
Yeah, I think before I would do anything else I would run a pipe cleaner thru the socket holes and make sure they are clean, perhaps with a bit of DeOxit of it.
Larry
Threads: 16
City: Kokomo, IN
You might try resoldering the pins on the tube.
Threads: 64
Done all of the above. I usually change all wiring, remove each pin socket, clean and tighten it. All pins have voltage, albeit 30% higher than normal.
I just found out that original 10watt 1,5K B+ resistor had been replaced with 1.0K resistor, hence the elevated B+ on all tubes, but that should not be detrimental to the glow issue.
City: Sedona, AZ/Placentia/CA
Fields, nice to post a link to the schematic. Every radio with an eye tube I have worked on (not your particular tube) has had a 1meg resistor either in the tube socket (mostly) or external and are a source of problems.
Threads: 64
@Jerry,
This one does not have any resistors.This particular set up is very interesting and unusual.Unfortunately, I am still having difficulties (or may be just ignorant) with a postings, but the schematic is on the NostalgiaAir and if you don't mind to see it there and let me know what you think, I would appreciate it. It is Airline 04WG803B. Thanks.
Appears your right fields. Not familiar with that tube. Here is a link to the schematic for others.
Jerry
http://www.nostalgiaair.org/PagesByModel...011032.pdf
Threads: 64
Got the new tube, everything's fine, response to the tuning is OK. Thanks for the hint. Have a question on B+ voltage. The 1500 ohm 10W resistor at the rectifier had been replaced with a 1000 ohm. Could be on the account of the half dead E-caps.Now, after recapping, my B+ at the plates is 230v instead of 180v. How detrimental is it for the occasional usage of this set? Thanks.
Threads: 18
Tame the B+ to specs. No telling what excess voltage might do to your set. Use dropping resistor's) in voltage divider to achieve factory specs.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit. That would rem...alangard — 09:30 PM |
Tim
Well...a chassis is metal. Magnetic or not, it does not matter.
A transformer has some hum to it. It is natural....morzh — 08:40 PM |
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM |
Shadow Meter Bulb
Ross
I am not sure what current limiting effect the incandescent provides.
They are two different parts of the sch...morzh — 08:31 PM |
12' Philco
Bob
Thanks for that photo.
I have been looking for it, and I cannot find anythinmg on the web.
I forgot it was here...morzh — 08:29 PM |
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55.
I ...georgetownjohn — 07:31 PM |
12' Philco
There was also this Philco!
klondike98 — 07:25 PM |
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM |
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM |
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo
This is something alright. I'm go...RodB — 06:26 PM |
