Ipod hook up
4/5/14 I know some of you have done this - I have a 53-1750 Radio Phonograph console. If I wanted to play my Ipod through the radio, how would I do this? Connect wires into the antenna leads? Hook into phonograph wiring?? I don't want to fry anything !!
Thanks.
Link to teh sch please.
No;
If you were going to do it at all you would have to connect it through the audio circuitry, that is if you don't have a short range transmitter like a SSTRAN. If the set does not have a power transformer I would not do it at all, it's a safety hazard.
Use the phono input wire. The connector should be similar to an RCA jack. Get the proper connectors and splitters and it works very well. I use this wiring on my 47-1230.
Use the phono lines.
It would be a god idea, both to match impedance and protect your ipod, to install an 8:1k ohm audio transformer. Use a switch to disconnect the phono when using the ipod.
I looked thru the documents and did not see one. Might have missed it though.Jim Dutridge — 07:16 PM
Please tell me this was it, I replaced resistor 27 and it's playing on the broadcast band. I am afraid to change the ban...osanders0311 — 06:12 PM
So far still no broadcast, I am posting pictures of #14 Oscillator and also a resistor #27 which connects to an XXL tube...osanders0311 — 04:02 PM
I believe there is that document, and I think we might have it in the Library.morzh — 03:29 PM
5U4 vs 5Z4 tubes
There are currently 1246 online users. [Complete List]
» 3 Member(s) | 1243 Guest(s)
