90 dial drive mechanism repair
The 90 that I'm working on has a very sloppy dial drive mechanism; the shaft has a little slot worn in it, and the matching hole in its bracket is worn, too. I have some ideas from old posts on the ARF, but I thoght that I would ask here.
Tim KA3JRT
I fixed it; I found an old hollow tuning shaft (to use as a bushing) in my assorted junk (probably a shaft from one of those late 40s Zenith sets), which had a quarter-inch I.D. I slid it over the tuning shaft, and carefully centered the shaft over the original hole. I used a fine-point Sharpie marker to draw a circle around the new bushing, and reamed/filed the bracket to the diameter of the bushing. I then pressed it into place and soldered it, trimming the new bushing to about one-quarter inch or so. The dial was then reassembled, and the mechanism was oiled. It now works perfectly, and should be good for another 74 years.
Tim KA3JRT
Hey Tim, don't leave us in suspense....
Could you add some pictures please? Icon_smile
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1261 online users. [Complete List]
» 1 Member(s) | 1260 Guest(s)
