650X shadow mast sloppy
The shadow mask on my 650X is loose and moves around. It seems in good shape and the 2 tabs lock into the bracket fine. It would seem it is warped from being held in a curved position for 72 years or maybe it shrank? Any ideas on how to repair it so it does not move side to side?
Thanks
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Here's an idea. All of mine move side to side about 1/10", maybe a little more. But, if it moves, try this. Cut thin fine strips of tape, just enough to place along the edges. This will help keep it tight. It doesn't have to be exactly as I've stated, but anything similar to achieve the same result. Keep in mind the shadow mask does bulge out just a little.
Second, the dial disk shouldn't rub against it. There is an inset screw in the dial disk mount(the dial scale mounts with a retaining clip). You can loosen it, and move the dial mount out just far enough to avoid the rubbing. Also, the two upper tabs that the dial scale sits behind, may need to be bent out slightly to keep things in alignment. That was the dial no longer rubs the shadow mask, causing it to move.
Last, make sure if you move the dial disk out, to re-align the dial scale so your tracking remains proper.
Does this help?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I have way more then 1/10 of an inch side to side play. I have about 15 KHz slop. IMO any slop would be too much as it would be impossible to accurately align the dial yet the radio to it. My 620 uses a similar mask and it has little or no play. Go figure. I guess I will try to build some shims to fix the problem.
Bill
Bill, make sure the dial scale isn't "rubbing" on the shadow mask. There should be a small gap between the two. It shouldn't be moving unless you force it. I understand it can move when shifting the radio from place to place. I have very slight movement in any of my shadow mask, and I have to make it happen. Sounds like this one seriously warped.
-Brian
Help with Readrite 410 tube tester
I fixed it. The filament selector switch is not that great of quality. Cleaned it and it takes some fiddling with to get...daveone23 — 06:58 AM
Looking for place to donate unique Philco Philco J-1930 Prototype
It's a vacuum tube set and it's over 60 years old.  My uncle acquired it for my parents when Philco was done with it, an...jeibner — 10:24 PM
Hi J Eibner, Welcome to the Phorum.  Lots of Phriendly Pholks with Phine (See a pattern here?) advice. It is very...MrFixr55 — 09:54 PM
Philco 89B code 123 newbie
Or you can do what Terry suggests. Thx Terry for remembering that. A lot cheaper. I remember an article about that, b...MrFixr55 — 09:07 PM
Philco 48-200 alignment questions
Thanks to everybody for all the info so far. RodB, thanks for the additional info. I worked on this radio years ago a...transitony — 08:40 PM
Now that I've been thinking about it somewhere I saw a replacement made using a section of pvc pipe and a cap to cover t...Radioroslyn — 08:25 PM
Terry's gimmick cap is two insulated wires twisted together about 2 inches long, one wire attaches to the generator outp...RodB — 07:46 PM
Hi, in this case I would be certain that pin 7, which is B-, of the 14A7 is not "hot". If it is then reverse t...RodB — 07:39 PM
Yup. The gimmick is to take the place of the 100mmfd cap you don't have.Radioroslyn — 07:34 PM
Thanks for the reply Terry. Yes I am definitely using an isolation transformer. If I work with your method and connec...transitony — 07:29 PM
There are currently 3074 online users. [Complete List]
» 2 Member(s) | 3072 Guest(s)
