I got one!
Finally found an AK 'little stove'! A model 53. Actually stumbled on this at an antique mall I usually never find anything of interest in this afternoon. Other than the missing fine tuning knob it appears complete. Tuner is currently stuck, but I don't see any serious damage inside.
nice project, Looks heavy
Keep the stove but find a radio chassis that is less rusted.
Most AKs you find around here have some rust on the inside. It's that wonderful, humid Ohio air. I doubt finding another complete chassis is going to happen as this one is a bit different from the AK breadboxes I have lying around. For one thing, this unit has a regular electro-dynamic speaker, not the early high-impedance units. It's an eight tube chassis that appears to use push-pull 71's as outputs. Also, I think the 'chassis' is actually part of the cabinet. It appears you can pull out the RF deck and transformer deck separately, but that's it. Actually, it looks like getting the parts out might be a real pill. The original AK instructions even mentions having to cut some wires! Eek!
Not so long ago Terry got one.
Good score! Those are not seen everyday so you did well. I like small funky consoles like those.
Large knob on left is from an earlier AK set.
Heavy ain't it!!!!
Yep it IS heavy. I was wondering about the knob. I wonder if the spare knob from my parts 42 might be a better match or just leave it be?
Wow nice tind! But I would not liked to be zapped Leaning on a all metal radio if the electronic was not up to par....Wow wee...
I think the AK-42 knob would work.
A picture with the correct knobs now installed. Makes the radio look a good bit different. Also, got the tuner sort of loose. Two of the gangs turn, but the drive belt for the third is damaged and it appears someone has loosed the nut on the back, causing all the plates to become mis-aligned! Oh well, that can be corrected and maybe a full tuner alignment will help with performance. Oh, the transformer appears good, so major plus there! Icon_thumbup
If you need a new belt Adams sells replacement bronze belts for A.K.'s:
http://www.adamsradio.com/
Thanks! I'll have to see if the broken belt is the long or short one.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2328 online users. [Complete List]
» 2 Member(s) | 2326 Guest(s)
