Threads: 21
City: hesperia,ca.92345
can anyone tell me what a common lug on a bathtub cap is used for, is it a ground lug, if so how is it different from the other bathtub cap with out the common lug
thank you for your help
john
Threads: 573
Caps do not have ground lugs, they just have lugs. These can be connected to whatever including ground.
A cap with a common case and two lugs is simply a dual cap with one common. Connect it any way you will.
City: Sedona, AZ/Placentia/CA
John, to expand a bit on Morzh's comment, if your referring to the black Philco bakelite caps they generally have a lug on the end the mounting screw goes through. This lug would be chassis ground. Components inside the tub often require one end to ground and this is used for that connection. Should you find a can without a lug on that end (I don't recall seeing any) it just means that the component(s) inside do not need to be connected to ground thus the lug was left off.
Make sense? Chuck's Philco repairbench site will provide a listing of the various tub caps listed by the number etched in their sides. It provides the value(s) of the internals and their connection point.
Chuck's site: http://www.philcorepairbench.com/bblokcap.htm
Jerry
(This post was last modified: 04-26-2014, 06:50 PM by jerryhawthorne.)
Threads: 573
My bad, I was thinking of Philcos where I have seen them called many things, often derogatory.
Jerry
City: Kentucky
Those little guys are expensive.
Threads: 92
City: Clayton, NC
Those are "audio quality" oil-filled caps. Yes, they are expensive.
You mainly see them in audio-phile gear or test equipment.
Some high-end radios also used them. My Scott 800B has them. I tested several and they were all right on, so I left them alone.
I have a box full of them I got from my friend and mentor Bob Timms. Many are appropriate values for my Scott, I am saving them for my Great-Grand Children to have in case one of the ones in my Scott eventually fail.
In fact, I believe that when the atomic apocalypse comes, the only things left will be cockroaches and oil-filled caps.
City: Kentucky
Quote:In fact, I believe that when the atomic apocalypse comes, the only things left will be cockroaches and oil-filled caps.
...and I will add - the tar from thousands of restuffed Philco bakelite blocks. .  ..Somewhere, scattered across the globe.
Threads: 573
No....it will mix with asphalt roads.
It will only be found in rural areas....
Threads: 92
City: Clayton, NC
If you melt the bakelite block tar in a bowl and add sugar it's great on pancakes.
Threads: 573
Or you can then introduce yeast, fement it, take it to a nearby still and make "Philco noir" moonshine.
Threads: 18
Pardon me, but I thought bathtub caps were used in HV circuits of CRT high voltage supplies in ancient televisions and could cause house fires when failed, but it has been a while...........
Threads: 573
Bathtub cap is the one you charge and throw in a bathtub while your MIL is enjoying her bubbles.
City: Kentucky
..I'd like to do that with the bathtub AA5..
Hello
I am new here and I could use some advice. I am working on my 1955 Stude/Philco car radio and have determined tha...Pdouglaski — 06:43 PM |
Thank you MrFix55 and GarySP with helping with the Antenna, for now I am placing the Antenna on the back burner and work...osanders0311 — 02:24 PM |
Yes, Michael. But strangely enough, I managed to keep the original veneer. I must admit that I don't really like it, so ...RadioSvit — 02:21 PM |
Good radio.
I bet there was a lot of veneer fixing.morzh — 02:16 PM |
>> it is because I am retired and a little demented.
You have just the right amount of it. No perfectly sane p...morzh — 02:14 PM |
Old Zenith 5S-29 tube radio. First turn-on after repair and reception quality testing. Demonstration of the operation of...RadioSvit — 01:27 PM |
Welcome to the Phorum, osanders0311! Regardless how far you intend to restore this set, first priority should be replac...GarySP — 11:51 AM |
Joseph, it is because I am retired and a little demented. My problem is that I wanted to own a collection that spans th...MrFixr55 — 11:29 AM |
Wow, here I am with only two restored radios. I’ve got to boost those numbers! If you can’t run with the big dogs, you m...jrblasde — 10:04 AM |
Hello MrFixr55,
That will for sure keep you out of trouble!
Last Sunday was spent mostly doing yard work anyway the we...radiorich — 09:50 AM |
There are currently 344 online users. [Complete List] » 1 Member(s) | 343 Guest(s)
