Philco 90 help
I just finished recapping and checked all resistors and all tubes tested good. I have the philco 90 with a single 47 output tube. I don't get any signal unless I touch the grid cap of the 1st detector tube. Then everything comes in ok. I've read somewhere what this can be, but I can't find that thread anywhere. It's my 2nd restore. Can someone please help?
You will have to check coil #2, #5, and #7, one or more will most likely have an open primary winding.
Greg B
My bet will be on coil #5, let us know what you find.
Gregb
What does the voltage read on the plat of the 24 RF tube?
M R Radios   C M Tubes
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
There are currently 3320 online users. [Complete List]
» 1 Member(s) | 3319 Guest(s)
