Philco 90 with Twin 47 Tubes in PP
Sorry missed that you tried already, try pulling one or two turns off the coil and try resoldering.
Gregb
If while taking the turns off the wire proves brittle, even if you could resolder - don't.
Started unwinding the Primary, Had to remove 65 inches of it to get to good wire. Looks like something maybe the Tape made the wire rot. The Primary has 53 dc ohms the Secondary has 56 dc ohms
Re-soldered to lugs. Got nothing to loose will reinstall and see what I have.
Gary has a bunch of 262 Coils that would trim to 260, just finding one to fit in Original can is the task
sent Gary a Pic of original.
Later
Bob
I have a replacement IF coming for the 2nd IF
So I went ahead and re-stuffed all the Caps and replaced any bad resistors and a few Mica caps that were flaky when value was checked.
I have a problem with Resistor Item 32 missing. Schematic shows a 499K in the Det Amp circuit .
Other than that just awaiting the 2nd IF
Bob T
It is item 32 and it is present on the chassis drawing.
As long as the primary has continuity now difference of 3 ohms DC resistance should not effect the inductance enough that you can't adjust the IF to 260 kc. In fact they may have been mismatched to begin with, either through accepted margins of error or because they wanted a step up between the primary and the secondary windings. I would try re-using the original IF coil if you can, and save the new one as a spare.
Chassis again SINGING STRONG
Thanks Ron for a good schematic
Thanks Mike for the IF Coil and Tom for the 2 110pf caps.
But I did end up putting the missing Item 32 Resistor in AND
Used the Original IF transformer. Had it in and out 4 times
Repaired break in Primary
The Secondary checked good with ohm meter 53 ohms but would not work in radio, Cleaned wire around rivet and soldered it. That did it
Need to do alignment , but it is playing very well . Impressed with the 2 47 Tubes. Also I am running the Console Speaker with it. May not sound as well with the 8" Speaker.
Thanks again for the input from members here. It was helpful and made things easier
Bob T
UPDATE
Powered up to do Alignment, NO RF !!!!!!!!!
Went to check OSC Tube Voltages. Touched my Meter probe to Plate Pin 2
RF returned. So osc was not running
Cleaned tube pins and cleaned pins and socket with contact cleaner.
Came back 2 hours later. Aligned IF , went very well. Peaked nice @ 260KC
Went to to rf alignment , rf disappeared again. Once again touched Pin 2 of OSC and rf came back.
This time I re soldered the connector pin 2 and bent the contact points closed.
Completed rf alignment , again all went well.
If I loose rf again will try another 24A Tube. I do not see any bad connections in the area.
Time will tell
Meanwhile enjoying 40's Hit via my SSTRAN Icon_clap
Bob T
Yes I think a tube (have you checked it BTW?) might have a problem starting oscillating. Could be low gain.
Also remember that #13 and #14 items?
In case another 24 tube does the same you could possibly try to play with those.
24 Tube checked very strong on my TV-7. Item 13 was replaced and 14 is 8.2K as found in it and suggested by Ron.
Been Playing over 2 hours trouble free
Bob T
What the tube checks like is not quite everything especially when it comes to oscillators.
Once it starts though it will oscillate forever without problems - it is the start-up condition that is finicky. This is where the tube might potentially influence the behavior of the whole circuit.
You tester checks for certain parameters, it does not check for the whole performance.
The testers provide a starting point, best tube tester going is the piece of equipment its meant to work in.
Gregb
OK been Playing Flawless.
Now for next fix
Dial Tuning is sloppy. Part shown in Pic is worn out and allows dial to drift.
I need the Part Pictured and marked .
Thank You
Will post in WTB also
I have both 70 and 90 having zones where it is slipping. Guess it is quite a common problem for this type mechanism. I found out that moving the dial just a little along the axis helps it but you have to make sure it does not rub against the escutcheon.
Another thing, the grease tends to accumulate there and makes for less friction, so those need to be degrease.
Honestly, I do not remember this spring-pulled washer in either my 70 or 90. I wonder if they added that (or it was a home repair remedy) to increase the pressure of that rim onto that groove. I am not sure it is a factory solution - hadn't seen it before.
Mine is not slipping. The part marked has worn egged shape so allows Dial to shift.
I need the part shown and marked as such.
The added spring and washers are the result of last owners attempt at a fix.
Replacing the Part marked with a good one, I believe a 1/4 dia bore will solve my problem
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
@ Joseph, get off the porch and run with the dogs. You fixed one, grab another. @ Morzh, I think that we are the same ...MrFixr55 — 08:59 PM
Wow! Now that is something! I’ve never seen a Philco like that, but it’s pretty mid-century.jrblasde — 06:40 PM
I've run the radio for a couple of hours today, and all is well. It's a remarkable sounding radio! I'll go ahead and upl...jrblasde — 06:05 PM
Gary - Thanks for responding!  I hadn't actually taken possession of it at the time of my post but since you said it was...fklown — 03:32 PM
Philco model 40-100
Marion; Replacing volume controls was something some service shops did in years gone by to make a little extra profit...Arran — 03:24 PM
There are currently 464 online users. [Complete List]
» 2 Member(s) | 462 Guest(s)
