Another Crosley from Kutztown
You may remember last fall I picked up a Crosley Tridyn at Kutztown and gave a blow by blow discripiton of it's repair.
http://www.philcoradio.com/phorum/showth...p?tid=7614
Well this spring I picked up another Crosley a model 51. The 51 is very kewl set two tubes but will drive a speaker listening to local stations. This pretty amazing for a 1924 set using 201A tubes.
Back then it was available in four different versions, plain https://www.google.com/search?q=Crosley+...B750%3B418 special, https://www.google.com/search?q=Crosley+...B480%3B360 ,special deluxe https://www.google.com/search?q=Crosley+...B480%3B360, and portable https://www.google.com/search?q=Crosley+...B429%3B374 . If you closely at the portable the panel layout is different that because the set is a early versinn Mine is the deluxe. What that means is it has a larger cabinet so the batteries can be stored inside.
One of the thing Powell Crosley was famous for was designing the book tuning condenser. Crosley was set on making radio affordable for the masses. One of the more expensive parts was the tuning condenser. Most then where made of brass or aluminum and required machining to fabricate. The book condenser used two squares of Bakelite with a thin metal plate covering one side of each of them. A hinge was added so the distance between the two plates could be varied. Two springs and a cam were used to adjust the capacitance (the spacing between the two plates) And there was a thin insulator between the two plates so they wouldn't short. You can see one here on the right side of this model 50 chassis.
https://www.google.com/search?q=Crosley+...B640%3B543
As for expense of the set the plain version sold for $18 less tubes and batteries. Covers the AMBCB and a little extra in five steps. One of the 201A's is a regenrative detector and the other is the audio amplifier.
More Later
Interesting.....
I learned something today! now I can shut down my brain, Icon_lol
Kirk
Well, Crosley radio business started from the fact that his son asked for a radio and Powell went to look and was appalled by the kind of price he saw.
And he was the first ever to offer the warranty of 1 year and money-back.
What a fella!
That delux model looks like a nice set. Good luck with it Terry.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2324 online users. [Complete List]
» 2 Member(s) | 2322 Guest(s)
