Philco Model 86
Hi;
Just bagged a 1929 model 86. This is 85 years OLD!!!
Does anybody have any info on this that has a parts list and pinouts and ohms resistance on the transformers, and parts location etc. What is the B+ voltage suppose to be?
Also this has a combo resistor/capacitor coils part 7, 12,17..never seen that. Can you restuff that?
Also,,, what is inside the 2 capacitor cans? .....The smaller one is soldered shut..... Can you open it and restuff ?..... Also the larger one....what's inside that big box? Tar? Is it hard to remove?
Can you restuff that one too?
Just need some help before I start this project. Heres some pics. Bought on Craigslist for $40
http://s270.photobucket.com/user/lowellv...sort=3&o=0[/img]
http://s270.photobucket.com/user/lowellv...sort=3&o=8[/img]
http://s270.photobucket.com/user/lowellv...sort=3&o=1[/img]
Buzz
http://www.nostalgiaair.org/PagesByModel...029653.pdf
http://philcoradio.com/tech/images/86.jpg
The latter has values (next best thing to parts list).
If not enough, Chuck is your goto guy.
Already have that schematic. I need something detailed.
thanks
It is auite enough, the latter one with values.
And, IMHO, measuring resistances of transformers is mostly...unnecessary and borderline useless.
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
There are currently 3992 online users. [Complete List]
» 3 Member(s) | 3989 Guest(s)
