48-482 FM antenna
While waiting for my caps to arrive, I have been looking into the FM antenna situation on my radio. I have the "line cord antenna" which connects to pin 2 of the little plug on the chassis back. I have seen pictures of these radios with a very different FM antenna setup, a wire running in a single loop around the very back of the cabinet, but attached to the same pin 2. Having read Philco's instruction sheet for the radio, I see they say it should NOT be externally grounded. Looking at the schematic, I was thinking that using the present "line cord antenna" as a virtual ground, attached to pin 1 of the little plug, and a single loop antenna attached to pin 2 might give good results. Attached are the relevant schematics. Any thoughts ?
[Image: http://33.media.tumblr.com/fe95abf5dc211...1_1280.jpg]
[Image: http://37.media.tumblr.com/a6f46cbc42144...2_1280.jpg]
[Image: http://38.media.tumblr.com/422aee0f3f7b5...3_1280.jpg]
Leave the antenna connected to the line cord as is, it works very well. The location on the power cord is located 1/4 wavelength at FM broadcast freqs from the internal line to chassis caps which act as a ground to chassis. Therefore, 1/4 wavelength down the power cord, you are at a relative signal voltage maximum and this is where the capacitive coupling to the antenna input is located.
When operating correctly, the reception with the line antenna is excellent.
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4381 online users. [Complete List]
» 1 Member(s) | 4380 Guest(s)
