Oscillator 06620 repair?
I am working on a Philco 89 ( Code 123 ). The Oscillator is not working. I removed Oscillator Coil 06620 and found the winding between pins 1 and 2 open. Pin 1 goes to the cathode of the Detector / Oscillator tube ( 77).
I removed the coil. I can not see any windings. Please tell me how I go about repairing this coil?
All suggestions are appreciated.
nv3g
I baked the Oscillator 06620 coil for 30 minutes at 200 degrees in the oven. It removed all of the wax. I can now see the outer winding that goes to the cathode of the Detector Oscillator tube. I may try to rewind this outer winding myself.
nv3g
You are on the right track now. Icon_smile
If you run into any difficulty rewinding that coil, let us know. It is actually quite easy to do.
I use #38 gauge wire for the outer winding which always goes bad. Be sure and pay attention to the direction the original winding was wound, placement of the winding on the coil, etc. Remove the old nitrocellulose insulator whcih the original winding was wound on, and use new Mylar tape instead; the breakdown of that nitrocellulose insulator is part of the reason the original windings fail.
I had a similar problem with my Model 60 and had to rewind one winding on the oscillator and antenna coil. Followed Ron's suggestion on rewinding and worked out fine. I wasn't able to find #38 wire and used #36 instead. Radio plays beautifully now.
Harv, WA2AAE
Harv
nv3g, please check your e-mail. Icon_smile
The oscillator coil winding going to the cathode of the Oscillator/Detector tube is rewound. The oscillator is now working properly. I need to change two resistors that have gone very high in value.
Thanks to everyone who gave me suggestions. Another Philco radio has been resurrected from not working at all to a working radio. Hurrah!
nv3g
Icon_biggrin
Hickok AC51 tube tester
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
Platinumblonde36 — 12:58 AM
Platinumblonde36 — 12:57 AM
I'm finding some strange things in my set and for the most part it's also original, so I need to start going over everyt...Platinumblonde36 — 12:55 AM
There are currently 4970 online users. [Complete List]
» 2 Member(s) | 4968 Guest(s)
