How safe are these plugs?
I now have the sneaking suspiscion that in the half-done restoration job, someone replaced the power cord with a new cloth covered cord already. I was amazed at how good condition it is... no frays at all, etc.
I came across Sundial wire's website selling cloth cord kits. They ALSO sell these kinds of "Acorn" (brand) plugs which is identical to what mine has:
http://www.sundialwire.com/PN2RECTBN.aspx
No wonder the cord and Acorn plug end is in such good shape.. they are modern made.
How to my question, how safe are those kinds of plugs? They have nothing more than a small piece of cardboard covering the wire and screws inside:
[Image: http://www.sundialwire.com/images/produc..._thumb.jpg]
It says it is UL recognized. Sounds to me like they would be fine, unless they are lying about that fact. I have no direct experience with that product, so I can't say for sure, but it seems fine.
That type of plug was used for years. It is perfectly safe if it is wired correctly. Be sure to use an underwriter's knot on the 2 internal wires to act as a strain relief. Make sure the conductors in each wire are well twisted together, and go under the screw in such a direction that they tighten under the screw as it is tightened, rather than get pushed backward. After wiring the plug, then put the fiber cover over it to cover the screws and wiring inside.
The plug would be fine even without UL recognition, it is not used in havy duty apps.
However, this cardboard piece first does notvwant to go on the pong, and then tries to slip off.
I am not sure it is even needed (old plugs do not have it) but they could've made it behave better.
I worked for Leviton Corporation for a number of years in their Q.C. lab as a tech. Leviton was a manufacturer of this type of replacement plug. This sort of plug came with the fiber piece to go over the exposed wiring. The slots in the fiber piece should just slide over the plug prongs, and stay in place by friction. If the piece has been removed and replaced several times, the slots can become too large. It is not absolutely necessary, but is there for safety.
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
:lol: We need to start a singing radio group! I play the guitar, so maybe get a few vocals? Anyways, Mike, I did try mou...TV MAN — 05:56 PM
And so does a barber shop quartet. mmmmmmRodB — 03:54 PM
There are currently 6637 online users. [Complete List]
» 1 Member(s) | 6636 Guest(s)
