511 series AF transformers
After replacing a burned out 71A tube I was getting one strong channel but no volume control. I figured I'd recap it and see what I got. While waiting for the new caps to arrive I went through the chassis more thoroughly and found that the output choke was taken out of the circuit with the speaker connected directly to the 71A and worse, the 2 AF transformers (#3077) appear to be open... I doubt I'll be able to find replacements and I don't want to put a lot of money into it. Is it possible to rewind these myself or use some modern replacements?
Hi
While these can be rewound, modern replacements are available for the audio interstage transformers from a few sources. You will want transformers with a 1:3 ratio.
Or, you could change the audio interstage transformers to resistance coupling. Details here:
http://www.philcoradio.com/tech/audio.htm
Scroll down to "Modification C."
Thanks Ron, I will try the resistance coupling if I can't find an appropriate match. This may be a silly question but, could I use a 110v to 36v power transformer (1:3 ratio) as a substitute? Also what kind of current rating should be used?
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
