Restoration of Philco 40-180
Can anyone tell me if it is OK to repaint the Cartouche metal plate around the radio dial on an original Philco console model 40-180? If I repaint that part, does it destroy the collector value of the radio?
Bill St
Hi
I assume you mean the escutcheon. And, yes, it is OK to repaint it as long as it is painted the same color as original, in order to maintain collector value.
Ron, Thanks for getting back to me on my painting question. I appreciate the feedback.
Bill St
Oh, shoot, there's a thread about this running amok elsewhere on this board. Plastikote's Odds & Ends line (the little stubby cans) paintcode #139S, "brass," is what I believe was recommended. (Someone had sanded mine and then painted it black.)
Hi,
I posted that. Make sure you get all the old paint off it before spraying. I think you will be happy with the results.
Take care,
Gary.
And here is the thread:
http://philcoradio.com/phorum/showthread.php?tid=1318
I recommend a chemical strip of the old paint if possible, and a Dremel wire wheel to remove any rust scale and clean out the grooves. Have some ultra-fine sandpaper ready to do the final "polish" of the metal if you do the wire wheel, though, as you may well plant swirl marks in the metal with it. This is the voice of experience speaking here... Icon_redface
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
There are currently 5895 online users. [Complete List]
» 2 Member(s) | 5893 Guest(s)
