How much toner do I need?
I need to refinish both a model 60 and a model 80. I have not used a toner before, so I do not know how much is required. Assuming I use the same dark tone and the same light tone for each, can any one tell me how many cans i need to order of each to do both radios?
Jim Cross
Hi Jim, and welcome!
One can of each will probably suffice, but to be on the safe side, order two of each (Medium Walnut and Extra Dark Walnut).
Edit: Depending on which version of the 60 you have, the coloring will be different. I believe you have the 3rd version cathedral (June/July 1935), based on your other Model 60 post? In this case, the color suggestions above are valid.
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
There are currently 1225 online users. [Complete List]
» 3 Member(s) | 1222 Guest(s)
