ok to strip?
Dumb question, but I'll ask anyhow
I have what I think is a 52 cathedral.
Some jackass thought the cabinet needed improvement..
Want to see if these were photophinish at all.
Too early a radio for photophinish I think.
Tim
Nope, no photofinish on a 51B...
Great news from Ron. That radio can be saved with a lot of stripping and refinish. Nice looking little cathedral.
Jerry
 One more thing though, use proper paint and varnish remover to strip the cabinet, lacquer thinner and acetone are not going to cut it this time. However the lacquer thinner and acetone are good from removing residue after you get the paint off. It looks like someone in the 1950s or 60s had a go at "Antiqueing" this poor model 52, that was the decorating trend of doubtful taste from that time, tackiness didn't begin in the 1970s you know.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1159 online users. [Complete List]
» 3 Member(s) | 1156 Guest(s)
