10-25-2014, 03:29 PM
Eric, Sorry to hear about your wife. Good News is sounds like she is recovering...Best Wishes to you and the wife..
BOL: Please help me get my mother-in-law off my back
11-01-2014, 11:42 PM
thanks to mr gumpy
http://www.ebay.ca/itm/UDT-silicon-photo...19d881eb56 installed photo cell with double stick tape to old cell. soldered on to old terminals WOW [Image: http://i1303.photobucket.com/albums/ag14...bbd17d.jpg]
11-02-2014, 07:59 AM
Glad it worked for you!
That was the third different photocell i tried, all three worked but that one was best. I also found that by changing the stiffness of the rubber bushings holding the needle bar and mirror in place you could alter the response. Softer bushings (made from RTV Silicone) gave a much deeper bass sound, while firmer gaskets (made from rubber gloves a-la Syl's method) reduced the amount of bass and gave a slightly tinnier sound.
11-02-2014, 03:07 PM
thanks
I have several head units think I will experiment with them hmm he has 9 left and only took a week sam
11-08-2014, 12:21 PM
Thanks, gentlemen.
I am going to order one soon. I've got an idea for rubber mounts for the mirror assembly. I guess we'll see if it works. Now I need to deal with the idler. All the rubber on the large end is petrified and broken off and the small end is gummy. Any suggestions? It's not how bad you mess up, it's how well you can recover.
11-08-2014, 07:57 PM
Eric
I just use double stick tape two small pieces on copper sides. new cell well cover most of it sorry I don't have that type of turn table
12-07-2014, 10:14 PM
HI Grumpy
I ordered one of the photo cells you mentioned in your commets and installed it with two sided tape. It works but it is very loud and distorted, sounds like it overdriving the phono input. Did you do anything to the amp input? Mine sounds like it is putting to much to the preamp for the phono. It is so distorted I cannot make out what is being said, but very loud. Joe Joe Bratcher near Louisville, KY
12-08-2014, 02:27 AM
eric
did you try adjusting modulation screws top of chassis left side first 2 screws to the front sam
« Next Oldest | Next Newest »
Users browsing this thread: 4 Guest(s) |
