need help 620 blocks (4989-DG)
  I sorry,,,I just need some help on WHAT physical size Capacitor,,,I can stuff in this 4989-DG block,,,it calls for 2- .09uf @ 600 volt caps,,,I bought to Sprague 6PS-P10,,, .1uf @600volts,,,can hardly get that in there,,, Am I using the WRONG items,,,I though that I need a cap that is polarized,,positive and negative ends,,,I'm confused with ones that don't have a Black Line ( - ) side,, Is there something else to use,,,can someone help me out,,,,THANK  YOU for all your time,,,just another NEWBIE,,,Ken Jr.   Icon_crazy
You should be using metalized film capacitors such as these:
http://www.radiodaze.com/product/62.aspx
These are small enough to fit inside the bakelite block.
You can get them from many sources besides Radio Daze.
Just Radios - http://www.justradios.com/
Bob's Antique Radios - http://www.radioantiques.com/supplies.html#caps <---my favorite cap supplier
Sal's Capacitor Corner - http://www.tuberadios.com/capacitors/
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
Rogers Majestic R-646
Vlad; I also have an R-646 but it's in rough shape, the chassis is complete, but the speaker is missing, and the cabin...Arran — 01:06 AM
Hi Larry, Back when this set was built, they did not use polarized power plugs. Technically, your chassis is sittin...MrFixr55 — 12:11 AM
Vlad, rather cool radio and for $18, I would have driven much more than 16t minutes or miles.! It does appear to be a T...MrFixr55 — 11:52 PM
I found this radio on my local Facebook a few weeks ago. The original price was 80CAD (about $57USD). Today I looked at ...Vlad95 — 10:32 PM
There are currently 1089 online users. [Complete List]
» 2 Member(s) | 1087 Guest(s)
