Model 43 - Speaker re-coning
Threads: 12
City: Calimesa, CA
Can anyone recommend a competent craftsman to re-cone the speaker in a Model 43 cathedral style radio?
I found some references to Hank Brazeal, but the phone number and email address don't work.
Thanks!
Threads: 574
Hank Brazeal had retired many years ago.
Threads: 275
City: Wilsonville
State, Province, Country: OR
If you go to the Resources page on this web site there is quite a bit of info on where to find various things. Speaker Repair is one of the listed items.
Threads: 275
City: Wilsonville
Looks like the speaker in the 43 is an 8" speaker ( according to the speaker data that Ron has documented see the file speakers.zip). You might want to try to re-cone it yourself if the voice coil is in good shape. Bob Andersen did a video on a similar 8" speaker using a cone from MAT Electronics. I was able to do a re-cone by watching his video. If you try the re-cone, be sure to put some tape over the voice coil slot to keep dirt out, any dirt that gets in there causes a problem.
Threads: 12
City: Calimesa, CA
Thanks, Bob!
I watched the video, and may try to re-cone the speaker myself.
(11-24-2014, 04:09 PM)klondike98 Wrote: Looks like the speaker in the 43 is an 8" speaker (according to the speaker data that Ron has documented see the file speakers.zip). You might want to try to re-cone it yourself if the voice coil is in good shape. Bob Andersen did a video on a similar 8" speaker using a cone from MAT Electronics. I was able to do a re-cone by watching his video. If you try the re-cone, be sure to put some tape over the voice coil slot to keep dirt out, any dirt that gets in there causes a problem.
Threads: 425
City: Boston
Rich Stamer, Sound Remedy in NJ. Good guy, good work, good prices. Google him up.
Good luck
Threads: 12
City: Calimesa, CA
Thank you, Paul. I will check him out.
(11-24-2014, 09:17 PM)Paul Philco322 Wrote: Rich Stamer, Sound Remedy in NJ. Good guy, good work, good prices. Google him up.
Good luck
Threads: 113
City: The Villages
+1 for Rich Stamer. He did a great job for me.
Eric
The Villages, FL
Threads: 12
City: Calimesa, CA
Glad to hear this, Eric! I have contacted Rich and will send him my speaker for the re-coning while I do tedious cosmetic restoration on the chassis--lots of light corrosion on the (cadmium?) plated surface. When I get the speaker back, I can start re-capping, etc., and hear confirmation of my progress, or lack thereof! I am assuming he will use the original spider and field coil, etc., and incorporate them in the re-coning? I would like them to remain.
(This post was last modified: 11-25-2014, 12:22 PM by jhgrahamjr.
Edit Reason: left out a word
Threads: 33
City: Horsham, PA
Another +1 for Rich Stamer. He reconed the speaker for my 37-630 last summer. Did a great job.
Jon
Those last photos were not very good,so I used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM |
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM |
Hello Dan,
That really turned out very nice and I also like that color it is not to dark .
I Have General Electric m...radiorich — 08:50 PM |
Table radio 51C or 52C?
The model 51 and 52 are identical mechanically, I'm not sure what may have been changed between the two chassis but one ...Arran — 08:18 PM |
Well today I installed the grill cloth board and the speaker. The speaker must weigh 20 pounds by itself.
I put the c...Dan Walker — 08:10 PM |
Unidentified Philco Bakelite
It's a British Philco, likely from the early 1950s. It has a very common layout for British sets starting in the post wa...Arran — 08:02 PM |
I suggest you take that look under the hood eventually.
Makes little sense to try to figure things out without looking ...morzh — 07:03 PM |
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM |
Morzh
There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM |
Looks like a Tropic of some sort.morzh — 04:26 PM |
There are currently 417 online users. [Complete List] » 2 Member(s) | 415 Guest(s)
