The Philco 39-30 progress
As promised earlier, we ordered some parts and began working on this radio last week.
I just completed the power transformer rubber wiring repair and this is the first one of these transformers I have done.  I also repaired the rubber wiring on the output transformer.  I also replaced the old power cord with a new polarized unit.
Now I am in the process of replacing the 3 electrolytics and all of the paper capacitors.
Tomorrow I may apply power and see how the power transformer measures.   Will something smoke?  Stay tuned to find out!
G.
When powering, first remove the 84 rectifier, power without it. This way you will check the tansformer.
Then you can do the rest.
Also, check the tubes, especially rectifier the tube, if it is shorted (which happens more often then one might think) it can take out your el. caps nd the transformer.
Well, good news, the transformer seems to be working fine and running cool!  I must have done the repair job correctly....
I want to show you the neat little fixture that I started using while doing this radio.  Just go to your local home supply store and find one of these 12 inch turntables.  Then add on a large enough piece of plywood to support the most common size radio you will work on.  Being able to spin the radio easily and work on it from all directions is a real time saver!
The electrolytics and most capacitors have been replaced.  Now the radio is playing, but not very well.  It passes a signal from the generator all the way through but not much volume.  So when I have time I will be looking into the first IF transformer for a possible open winding in the secondary.
G.
Okay, at this point in time, here is what's happening with this..... It doesn't receive any stations AM or SW.
(Power & audio transformers rewired, caps replaced, dial lamp rewired and much rubber wire replaced.)
The voltages match the schematic closely through out the radio.
The audio section is working ok.
A 470kc (if freq.) signal injected at the Antenna terminal is heard from the speaker.  Volume control works.
The local oscillator ( am ) runs and can be heard on a test (am)  radio.
So I hook a longwire to the antenna terminal and no stations are heard AM or SW.  I will continue roubleshooting.
Well, it is good that you can pass 470kHz, how about other frequencies, do they pass? (say BC band 550-1500kHz)
No, the sig generator does not pass thru on the broadcast band or SW band.
I just found my wiring error on the band switch on the AVC Line.  I put the .05 cap on the wrong location on the switch to ground.  This happened while I replaced the rubber wiring and capacitor on the band switch.
So, I have to pull the band switch back out of the chassis and move the .05 cap to the correct terminal.  That band switch is a pain to work around!
G.
Plus check your coils (antenna coils) for continuity if it still does not work after that.
So there is good news today.
I moved that .05 AVC cap to the correct place and started to hear RF noise coming thru.
Did a quick If and AM band and SW band alignment and now it's working.  It seems that by tweaking those alignment adjustments, the trimmers and padders must have been worked free of the dirt and grime and they are now working.  So now I will run the radio for a while to burn in and watch for problems.
G.
Congratulations ! It always feels good when you get it sorted out and the radio works as it should.
Okay, now for another question, this time  about aligning this radio on SW.
At 10 Mhz, I am able to hear 2 WWV signals that are about 900 hz apart.  My question is which one is the true station and which is the image?
Should I use the lower signal or the upper signal to align with the 10 MHZ mark on the dial?  I am confused here.
G.
Thanks for posting your servicing notes on your 39-30. I have one of these radios myself and will reread your notes as I work on mine.
Tom
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 643 online users. [Complete List]
» 1 Member(s) | 642 Guest(s)
