Model 14 Bakelite block question
Hello all, and thanks for reading my newbie question.
I'm restuffing Bakelite blocks in a Philco 14 and just tackled part #44 in this Code 122 chassis, a Bakelite block labeled "3615-BM" identified in the parts list as a .1 uf capacitor.  Based on this information, I expected to find one capacitor in the block, but I found TWO capacitors.  The block has only two openings for interior cap leads.  I'm confused by the presence of two caps and of, course, they're not labeled (other than the block itself).  Why am I finding two capacitors in a block intended for only one?  Were they coupling two caps to arrive at the intended value?
Thank you, in advance, for your replies and insight.
Mike
Amherst, WI
Mike, K9UW
Amherst, WI
Hi Mike, It looks like there was a replacement in the block capacitor Index.the 3615 BM was replaced with a 3615ODG which is 2 (two) .05 caps.
  http://www.antiqueradios.com/philcorestorer/page10.html
http://www.antiqueradios.com/philcorestorer/page9.html
Hows that dial coming along?
(12-18-2014, 05:58 PM)doug-5er Wrote:  Hi Mike, It looks like there was a replacement in the block capacitor Index.the 3615 BM was replaced with a 3615ODG which is 2 (two) .05 caps.
Hi Doug!
The 37-11 dial project is on the back burner until the replacement dial arrives from RadioDaze. Figured that I might was well mount the new dial before engaging in the struggle to get the mechanics working correctly. That order was placed two weeks ago, and I'm still hoping it arrives by Christmas.
Thanks for the links that update and define that block. That explains the two caps in the block, but the leads came up through only two holes (the third hole in the block was unoccupied). After posting my query, I carefully pried out the caps and found the leads from the two caps wound together at one end. The other end was too disturbed to assess.
In a situation like this, where the service bulletin says there are two .05 uf caps in the block and the radio's parts list says the part is .1 uf, I'm inclined to think that they used the block's two .05 caps in parallel to achieve the .1 value required in the circuit?
Confession: I actually like re-stuffing Bakelite blocks!
Mike, K9UW
Amherst, WI
Mike, K9UW
Amherst, WI
That would be my guess as to the 2- .05 caps. A .05 is 50000 mmF,A .1 is 100000 mmF. Don't know if you have one of these but they are a great thing to have on your bench or work area.Print the link and keep it handy Icon_biggrin Icon_biggrin
http://www.turretboards.com/capacitor_co..._chart.htm
Lots of times substitutions in production runs were made according to what was on hand, and rarely documented. That's why this is so much fun.
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 642 online users. [Complete List]
» 1 Member(s) | 641 Guest(s)
