I have a philco xf19 radio and it works great. any idea of what it is worth? cant find a price anywhere so far. help turtle
Welcome Turtle! Can you post a pic of your Philco model xf19? If so, that would help alot in determining the value for your resale-value question. Im confident that it would be worth your time posting a pic of your Philco xf19 here, and perhaps we can help you find more info on it as well? Icon_wink
I will take some pictures tomorrow and post them tomorrow, if possible Thanks for the reply! Turtle
cant get the pic to go. send e mail add if you would like a photo of the 1940 xf 19. turtle
Please look here for instructions on adding photos to your topic (newly revised):
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371
Here is the picture of the Philco XF 19.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
That is a 1940, Model 40-180. Where do you see xf 19? On the blue and white paper sticker on the inside wall of the cabinet? On the chassis somewhere?
That would not be a model number.
Chuck
...unless that is a Canadian Philco, in which case it is a Model 19XF.
Where are you, Turtle? In Canada...eh? Can you shed some light on this?
the information i got was wrong i found the model number under all the dust. it is a 40-180
Well...there...you...go. Mystery solved. Icon_smile
To answer your intital question about your set...find a copy of the most recent edition of Slusser's "Collector's Guide to Antique Radios." It is available at many bookstores and antique malls, and via this link:
http://astore.amazon.com/philcoradiocom/...1574325493
hi to everyone... any offers on my phico 40-180 radio (have to move)
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 984 online users. [Complete List]
» 2 Member(s) | 982 Guest(s)
