Proper polarity for filter caps in 1936 models
Threads: 40
City: St Clair Shores, MI, USA
Gents, just a note. Some may know this, others may not. Ed(etech) pointed out something very important. I'll use my 116B as an example since I screwed up on this model. Cap #101 which filters the negative grid voltage of the P-P 42s and center tap of the transformer, should be positive to ground (meaning the floating ground). The schematics on-line do not indicate this. But Chucks schematics do(sorry I missed that fact)  . I had mine connected backwards with negative to ground. Since there is only around 25v on this cap, my replacement cap didn't pop since it's rated at 500v. But, I noticed a low level hum with no antenna connected. I figured I would address this later on since it wasn't noticed with any level of signal.
Just thought I'd point this out since several of you hollow state fanatics(me included), are restoring these sets. The same cap is used on other models such as the 650(cap #77).
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
Ding-ding...
When I recently went back thru my 630 set that I had done back a few years ago as a newbie I found I had committed the same error. And yep, I used a 450v cap so it never popped. Didn't seem to make any difference but who knows what might happen in the future as the cap degrades.
Threads: 1
City: windsor, ontario, ca
Hi, i'm doing a 116b right now and just ran into this. So both sections of #101(8 and 10mfd) are positively grounded? I'm restuffing them now. Is the other 8mfd also positively grounded? And do you by chance have a copy of the schematics you used?
Threads: 14
City: Irvington, NY
Just remember that the most negative voltage of the radio is found at the center tap of the power transformer. Therefore the negative side of all three caps should connect there at that point.
Only the positive of the 10 uF cap (101) should connect to ground. The positives of the 8 uF caps should connect to each side of the filter choke.
Threads: 573
This will get re-discovered many times to come.....
Threads: 1
And luckily getting re-solved with this thread. Thanks!
Threads: 54
This is one situation in which a non polarized capacitor could be used, if practical to do so. Since it's only 25 volts it would be easier to do then with a typical filter capacitor, more compact and more sizes available to play with.
(This post was last modified: 09-18-2014, 12:06 AM by Arran.)
Threads: 11
City: Bellmawr, NJ
I would like to know if this same thing is suppose to be on the early(March 1935) model 620,,,,I went by the print on Philco page 6-25---,,,,,where # 68 capacitor is showing negative to ground(chassis),,,coming off wire wound resistor #70,,this radio worked GGreat for 3 hrs (Great volume,and sound),,,shut it off,,,turned back on next day,,,can't get 1/4 of the volume back now,,,( NO HUM either).. When I got this set ,,,these's parts were missing,,,didn't know about a floating ground,,,soo you are telling me that it should be (+) positive part of the capacitor is to go to the chassis (ground)?????  ,,thank you for all your Help,,,just a newbie,,,,Kenjr
Threads: 573
Yes the 68 cap should have PLUS to the chasis.
BTW on page 6-25 it shows no polarity.
http://www.nostalgiaair.org/PagesByModel...013804.pdf
Threads: 11
City: Bellmawr, NJ
(12-25-2014, 12:36 AM)morzh Wrote: Yes the 68 cap should have PLUS to the chasis.
Thank you for your help,,,,I will change this out tomorrow,,,Xmas 2014,,,and hope this fix will get my sound back,,,Happy New Year, to all on this site,,,,Ken jr
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
Welcome to the Phorum!
:wave:
