Model 37-60 resistor #19 value. Any production changes/
Hello:
I'm working on a model 37-60. I'm wondering if there was perhaps a production change with resistor 19. All the literature says it should be 9K and 2 watts. What is in place is a 30K, 2 watt dog bone resistor. It looks original. There are some other elements that are slightly different. I was wondering if there were any changes in production.
Dave
schematic here: http://www.nostalgiaair.org/PagesByModel...013205.pdf
I'd stick with the value of R19 found in the set, provided it is original, and measures the same as indicated on the part; probably wouldn't make much of a difference in this case - certainly not a show stopper. From what I've seen, minor changes were made all the time depending on what parts were on hand, or to improve reliability/performance, and documentation for non critical stuff just wasn't done with regularity.
My Philco 37-116 Restore
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
