Safe to powerup without Speaker?
Keith
I am not sure what you've done so far, but recap, recarb AND checking your tubes for 1) being what they should be and 2) being functional are the steps you should not skip.
The first thing I did was test my tubes but my bi-focals didn't catch the 7G7 swapped for a 7B7. All of the out of spec resistors have been replaced along with all the paper and electrolytic caps. From now on I will double check all tubes to make sure they are what they should be.
Keith
7G7 is a sharp-cutoff pentode; 7B7 is a remote-cutoff pentode. You need a 7B7 for proper AVC action.
7AH7 is the preferred substitute but 7A7, 7H7 and 7T7 will also sub.
http://www.nj7p.info/Tube/SQL/Tube_query.php?Type=7B7
Thanks Ron,
I'll order a new tube but it sounds like the7G7 tube probably isn't what's causing the loud ticking sound.
Keith
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
New Philco Repair Bench
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
There are currently 5951 online users. [Complete List]
» 2 Member(s) | 5949 Guest(s)
