Gilfillan Model 96 schematic
I recently rescued a Gilfillan model 96. Most of the tubes were gone.
My riders does not reference a model 96 so any ideas on tracking down a schematic would be welcome.
The dial scale is also in bad shape. Anyone who might be able to scan a decent one please let me know. Thanks
My Gernsback Service manual index shows a schematic for a 96B and a 96X. The B uses Metal-Glass tubes and the X uses Metal tubes:
http://www.radiomuseum.org/r/gilfillan_96.html
Send me a PM with your e-mail address and I'll send you a PDF copy.
(12-26-2014, 03:48 PM)Eliot Ness Wrote:  My Gernsback Service manual index shows a schematic for a 96B and a 96X.  The B uses Metal-Glass tubes and the X uses Metal tubes:
PM sent thank you
Schematic sent, hope it helps!
Thanks John
This is great.
Roy
Please keep us updated as you progress on this pretty rare set.
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 748 online users. [Complete List]
» 3 Member(s) | 745 Guest(s)
