Threads: 15
City: Weymouth Ma
Well for what it's worth it looks like a nice early set of tubes. They all appear to be Arcturus brand and the four metal look like Arcturus Coronet some of the very early metal tubes. Likely worth more than you paid for the radio
Nice buy.
Henry
Threads: 2
City: Southport NC
Ill bet the case used to look a lot like this one before the front trim pieces were lost. Maybe this will get us closer
http://www.radioatticarchives.com/radio.htm?radio=6470
Threads: 20
City: Portland, OR
(01-02-2015, 11:23 AM)JimZ Wrote: Ill bet the case used to look a lot like this one before the front trim pieces were lost. Maybe this will get us closer
Here are some additional pictures of the cabinet.
Certainly the Empire picture is very close.
Tubes are Traid (MG series) except the 25Z6 which is the Arcturus.
Thanks for all the input on this radio. My investment so far on the radio is $5.-Roy
Threads: 31
City: Lapeer
State, Province, Country: MI
Jim, That's a good catch. The Empire you referenced is a Chicago-manufactured radio. Empire was in the same building as Clinton Manufacturing and would have the 'Manufactured in Plant A or Plant C' tag. While the cabinets are not the same, the escutcheon certainly looks so. On another note, I'm curious about the bent chassis. I still think the radio is a Halson or Air King, and to the point of several others, inside a 'new' cabinet. Cheers! Joe
Joe
Threads: 2
City: Southport NC
^^Its a torment with no numbers because its one of those cabinet styles that a lot of companies made...during a particular time frame. We look at it and think "Ive seen that cabinet before" but when we look there are a lot of variations on the theme. Heck Ive even seen that same dial escutcheon on an early Firestone center dial set.
Fairly well made cabinet and the general shape is pleasing to a lot of eyes as well as the vertical inlay work. The veneer treatment on the top was well done and I don't think whoever made the radio would have bothered with those details on some "crap" radio.
Sooner or later well find an example that fits like a glove.
Threads: 31
City: Lapeer
Roy and Jim,
The Climax Conquistador at http://www.radioatticarchives.com/radio.htm?radio=7380 has nearly the same cabinet, and the lattice work is the same. The Majestic 1163 at http://www.radioatticarchives.com/radio.htm?radio=6457 has the exact same dial face. We are indeed closing the gap. As to the MG tubes, those could be replacements and not originals, like that newer orange Mallory electrolytic underneath. Joe
Joe
(This post was last modified: 01-02-2015, 05:15 PM by Joe Rossi.)
Threads: 20
City: Portland, OR
Threads: 54
I've seen sets with the tube numbers engraved on the sockets on occasion, usually on sets using older style tubes with fat pins, in fact it's very common in the earlier AC radios, like to prevent people from putting a #26 tube in a #71A socket since both are four pin types running on different filament voltages. But after 2.5 volt tubes became common this was less of an issue since everything but the rectifier was the same voltage.
(This post was last modified: 01-12-2015, 04:48 AM by Arran.)
Threads: 20
City: Portland, OR
Now that I look at the socket. A 25Z5 would not fit in the socked marked 25Z5.
Threads: 31
City: Lapeer
I don't think a 43 would fit into the socket marked 43 either. Hmmm...
Joe
Threads: 20
City: Portland, OR
(01-12-2015, 04:30 PM)Joe Rossi Wrote: I don't think a 43 would fit into the socket marked 43 either. Hmmm...
I think the following information from Radio Museum.org answers these questions.
"In 1935 Triad introduced a line of metal vacuum tubes with octal base in answer to the GE-RCA metal line. The early release of Triad line, with MG suffixes, included 13 types, all characterized by glass bulb inside a metal envelope."
The metal tubes in this set are Triad MG Series so they would have an octal base.
Threads: 2
City: Southport NC
I happened to be looking up a different model and remembered this thread.
One of these may well be really close
http://www.radiomuseum.org/m/pla-pal_usa_en_1.html
Not a big stretch to get from your cabinet to this one and the construction is similar
http://www.radiomuseum.org/r/pla_pal_652da652_d.html
http://www.radiomuseum.org/r/pla_pal_592a.html
(This post was last modified: 03-05-2015, 09:23 PM by JimZ.)
Hello All;
I found the CMB41L down in the basement, it is definitely a 1950-51 model, the capacitors have date codes ...Arran — 07:48 PM |
Hi, all the caps I order, other than the electrolytics, are of the 630V rating. No worries on it being too high, and no ...gary rabbitt — 05:46 PM |
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
There are currently 1317 online users. [Complete List] » 2 Member(s) | 1315 Guest(s)
