Philco 47-1230 Dial Scale Gasket
I've recently restored a Philco 47-1230 console. Everything is about complete, but I need to know the proper size and channel thickness of the rubber gasket that surrounds the glass dial scale. The original piece was so dry and deteriorated that it just crumbled into dust when I removed the glass scale. I also need the size and thickness to put a new round gasket on a Zenith 8-S-563 from 1941. Will this modern rubber be any problem (tight fit and lay flat) to installing this on the round and concave piece of glass? Thanks for any help, shaler78
For most cases, I have found that a new rubber band, cut open, and lightly glued with "Elmer's" to the glass side (not the side with the printing) will do nicely. For the other side, which would be the metal clips, glue another rubber band segment to the clip, and let it dry before putting the thing back together. The new "rubber" material should be just a little thicker than the "dust" you scrape off, but go slowly when putting it back together. If it seems to be too tight, remove what you have done and replace with a thinner piece of rubber band. Make sure there are no pieces of crud when you assemble the piece, else you will break the glass. If you are screwing into the wood, and the thread does not hold, you can fill the hole with a tiny bit of wood putty, and make a new pilot hole with a tiny drill bit or awl. Try the screw into your repair without the glass in place to test your result. Finish and polish the cabinet completely before you attach the dial scale. Dot the adjusting screws with a tiny bit of glue when they are all finished, to make sure they do not move again. Anyway this is how I do it. Slow and real careful. Same procedure applies to deteriorated gaskets for speakers, but be careful to make sure everything is bone dry so you can get the assembly apart again if you ever need to, (and you probably will.) Hope this helps some.
Philco 38-690
Oh....that is a Willie's radio. Expect that to go too high. Even though the prices have gone down, I suggest it will go ...morzh — 04:00 PM
Using a loop on a long wire 60B
There's also many DIY loop antenna options on YouTube your son may want to check out. Some are quite decorative and can ...RodB — 03:36 PM
Philco 38-690
They do, but much more effective in a closed cabinet.RodB — 03:20 PM
It could be hit or miss getting a salvaged loop to resonate for the desired station and it will require some sort packag...Chas — 02:50 PM
I searched but couldn't find an exact answer.  I'm giving my son my 60B that I electrically restored some 8 years ago (I...JohnCT — 12:49 PM
38-10T chassis Restoration begins
Hello Mr Fixr, years ago I had to wash two vcrs one was used by the school disctrict and the other was a family who had...radiorich — 10:53 AM
My dad's manager took the NRI course many years ago and gave me his course booklets. One of the course lessons was on r...MrFixr55 — 10:20 AM
Philco 38-690
There is a 38-690 for sale on eBay. Nice looking radio. Do those resonators/clarifiers really do anything?dconant — 09:34 AM
Philco 38-2 Low Volume
I have done the RF and magnetic tuning alignment. The magnetic tuning really does its job quite well. Had to do three tr...dconant — 08:41 AM
Hello Dan, Very cool !! morzh , I have seen people put computers and other items in the dish washer ! Sincerely Ri...radiorich — 11:26 PM
There are currently 2988 online users. [Complete List]
» 3 Member(s) | 2985 Guest(s)
