help with Philco ID
All, I'm getting ready to restore a Philco Radiobar and I need help with identifying the Philco model.
Here's are some pictures.
radio in cabinet
front
top
underside
unknown damaged part
The front of the chassis is stamped 36-76 but I don't believe that is a model number.  Also, can someone identify the part that appears to be damaged?
Keith
That is a Philco 610 chassis (1936 model year).
Thanks Ron, I can't find a 36-610 schematic on Nostalgia Aire but the tube lineup does match a 610 based on the Grillecloth.com radio database.  The 37-610 seems to have a different tube lineup.
I found it on Nostaligia aire listed under just 610.
thanks,
Keith
(01-25-2015, 09:13 PM)keith49vj3 Wrote:  Thanks Ron, I can't find a 36-610 schematic
That's because there is no such thing as a 36-610. It is a Model 610.
Philco did not start using the model year prefixes (i.e. 37-, 38-, etc.) until the 1937 model year.
I see you found it, good. Icon_thumbup
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
There are currently 2282 online users. [Complete List]
» 1 Member(s) | 2281 Guest(s)
