Installing a PM Speaker in a 38-7
Hello All,
I am new to this Phorum and am looking for a little help. I'm sure this topic has been covered several times but what appreciate a little guidance. I have a 38-7 which I am trying to replace the old speaker with a new PM Speaker. The radio was a barn find and the speaker is beyond repair. I have refurbished the radio and all that it is lacking is a speaker. I have purchased a replacement speaker and audio transformer. What I am in need of is a little direction in hooking up the replacement. More specifically how to handle the current three wire output to two and where I need to install the filter choke. Any help would be greatly appreciated. Thanks in advance.
Welcome to the Phorum!!
I'll add a link to the schematic for you so others have an easier time helping.
I've not replaced a field coil speaker with a PM but others on the Phorum have and I'm sure will jump on here.  In the mean time here are a couple links to threads on related discussions on the Phorum:
http://www.nostalgiaair.org/Resources/256/M0013256.htm
http://philcoradio.com/phorum/showthread...speaker%22
this is just a few threads...there are more.
You need to install a choke of equal or similar inductance and resistance instead of field coil, and then use matching speaker.
If your old speaker's field coil is good and you can remove it, you can use it. Keep it plugged exactly the way it was.
Yup, and remember to also use the pole piece with the choke/field winding. Hope you have room for it.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
