Selenium Rectifier Replacement
Threads: 31
City: Lapeer
State, Province, Country: MI
I am gathering parts for a little Zenith L403 ac/dc radio from the early '50's. It has a selenium rectifier (Zenith p/n 212-5), and says it's rated for 75 ma, no more info. Will a 1N4007 be able to replace that? Should I even replace it at all? Anyone have a suggested replacement? Thanks!
Joe
Threads: 573
You could test it, it is after all a semiconductor rect bridge, nothing more.
Otherwise, yes, 1N4007 are good, not sure if you need to account for voltage drop, if you do, a resistor in series will do.
Threads: 31
City: Lapeer
(02-15-2015, 06:14 PM)morzh Wrote: You could test it, it is after all a semiconductor rect bridge, nothing more.
I knew that YOU would have the answer for me. Thank you friend!
Joe
Threads: 423
City: Boston
When those Selenium Rectifiers fail they get very hot and really let off a stink. I would replace it, then you can enjoy without worry.
Threads: 573
Name me one eectronic component whose magic smoke smell like petunias
Threads: 31
City: Lapeer
(02-15-2015, 09:09 PM)Paul Philco322 Wrote: When those Selenium Rectifiers fail they get very hot and really let off a stink. I would replace it, then you can enjoy without worry.
Thanks Paul. Parts are on order and I finally did locate a source that states a 3W 300 to 330 ohm resister in series to make up for the voltage drop. Joe
Joe
Threads: 423
City: Boston
I have a red one of those lil Zeniths.
Threads: 113
City: The Villages
I've done quite a few Zeniths with the rectifier. I use either a 5W 100 or 150 ohm resistor in series and I've never had a problem.
Eric
The Villages, FL
Threads: 31
City: Lapeer
Paul, Mine is a grayish-white, belonged to my Aunt.
Eric, Once it is recapped, I'm going to measure the voltage off the rectifier, put in the 1N4007 and play with resister values. Thanks for the tip!
Joe
Threads: 18
Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Threads: 31
City: Lapeer
(02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Only 4 tubes in this radio, three 1 volt and one 3 volt.
Joe
Threads: 54
(02-17-2015, 06:13 PM)Joe Rossi Wrote: (02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
No, you need to calculate the proper size resistor in this case, it is much more critical then in a regular AC radio. Each tube needs 1.4 volts, not 1 volt, and the 3 volt one is actually 2.8 volts, too low and the set won't work properly, too high and the tubes burn out prematurely, so 7 volts ideally. If the original selenium rectifier is still working do some voltage measurements to see what the output voltage is before it gets to the filament dropping resistor, and after it.
(This post was last modified: 02-18-2015, 12:44 AM by Arran.)
Threads: 573
I lost you guys, it looks now as if you are talking of filament voltages, but then what does the rectifier and the resistor have to do with it?
Threads: 31
City: Lapeer
(02-18-2015, 12:38 AM)Arran Wrote: (02-17-2015, 06:13 PM)Joe Rossi Wrote: (02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Thanks Arran. I was aware that the filament voltages are 1.4 and 2.8 volts. I referenced them that way to indicate that the set only has 4 tubes a 1R5, 1U4, 1U5, and a 3V4, and atypical to some of the older 5+ tube AC/DC sets. There is already a 180 ohm 4W and 1750 ohm 5 watt just north of the rectifier. I want to be sure that in replacing it I have the proper voltage between SE1 and R13. Thanks again, input is always appreciated! Joe
Joe
Threads: 18
Sorry for possibly misleading anyone, (should have looked at schematic before typing,) and agree that in an AC/DC/BATTERY set, the end of the voltage divider feeds the filament string, and it is VERY important to do whatever is needed to get that final voltage correct. Even before restoration sometimes the filament voltage is too high with today's line voltage and an increase in the first an last resistor in the chain can correct the situation. This is doubly important when replacing a blown 117Z3 or equivalent in similar sets.
Thank you Rodb and Gary for helping with clarification on these capacitors. Other than the Tiny 630volt one I'm not sure...osanders0311 — 10:17 PM |
Hello All;
I found the CMB41L down in the basement, it is definitely a 1950-51 model, the capacitors have date codes ...Arran — 07:48 PM |
Hi, all the caps I order, other than the electrolytics, are of the 630V rating. No worries on it being too high, and no ...gary rabbitt — 05:46 PM |
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
There are currently 1247 online users. [Complete List] » 1 Member(s) | 1246 Guest(s)
