It makes nooooo sense!
I am working on another Tradio right now and I am having issues.
It is finished electronically and plays great Buuuuuuut when I put it back in the cabinet it loses reception. The cabinet is the antenna and the chassis has to be floating from the cabinet. If I play with the 35L6 it gets reception but then loses it. I move it back and forth and it come in and goes out. I have cleaned the pins and the socket but it is not helping. If I get it in the right position it will stay on. Then when I go and close the back it loses reception every time. Why is closing the back making a radios volume disappear?
What the hocke stix is going wrong? Tube is good so I don't know what to do!
And suggestions?
Kirk
If it is a frame antenna (a loop), your reception depends on orientation. See if turning radio around its axis gets the recption.
It gets the reception but once I go to put the back cover on it disappears. The back touches nothing but the cabinet which should make the reception better, not worse.. quite odd
Plus there is the issue of having to tilt the 35L6 to the speaker to get reception too.
Kirk
What radio is it? One of those coin ones? Photos?
Have you tried a different 35L6?  Have seen them with intermittent heater. If this doesn't help try crimping the socket connections.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 750 online users. [Complete List]
» 1 Member(s) | 749 Guest(s)
