Just purshased 116 tombstone and 91b
  I went to our club auction here in Dallas and I bid on this 116 Tombstone  and took it home for 190$ You don't see these come around to offen and I really wanted it . Nobs are gone but as far as I can tell everything else is there. This 116 will go in nicely with my other philcos. Restoration will begin soon and if you guys want I can post my progress, I came across a 91 cathedral all intact and will start on that one as well and payed 185$ for that one on ebay plus 35$ shipping, not bad A. Correct toner for 116 tombstone would be what ? Which v pattern cloth is best for 116 tombstone, radio daze or Richman designs ?  Im guessing extra dark walnut around the front face molding and the rest medium walnut for 116 ? Semi gloss or satin ?
Congratulations! (Oh, since these are cabinet questions, I moved this thread to Philco Cabinet Restoration.)
(03-22-2015, 11:24 AM)Fred Taylor Wrote:  Correct toner for 116 tombstone would be what ? Which v pattern cloth is best for 116 tombstone, radio daze or Richman designs ?  Im guessing extra dark walnut around the front face molding and the rest medium walnut for 116 ? Semi gloss or satin ?
Whoa, let's take things one at a time...
Correct toner: Extra Dark Walnut Ultra Classic (dye) toner on the top, sides, and the top, side, and bottom trim surrounding the front panel. This will allow some of the grain to show on the top and sides. Medium Walnut on the front panel itself.
Chevron (V) cloth to use? Richmond Designs.
Semi-gloss or satin? Neither. The original final finish was gloss. If you really don't like high gloss then use semi-gloss, but I would definitely not recommend satin.
Thanks Ron, how do you think i did on price? Pretty fair
To me, the 116B price was a bit on the high side, given its condition, but still not out of reason.
Regarding the 91B, well, that seems to be about the going rate for those.
(03-22-2015, 01:08 PM)Ron Ramirez Wrote:  To me, the 116B price was a bit on the high side, given its condition, but still not out of reason.
Thanks Ron
Ron is right about the gloss, BUT you have to rub it out too. Otherwise it is too reflective. And don't forget the grain filler or you might as well paint it satin.
Russ is absolutely right on this. Icon_thumbup Gloss lacquer that isn't rubbed out will end up looking a lot like polyurethane.
(03-22-2015, 09:49 PM)Ron Ramirez Wrote:  Russ is absolutely right on this. Icon_thumbup Gloss lacquer that isn't rubbed out will end up looking a lot like polyurethane.
Yes I can relate to that,  high gloss lacquer is about 90% gloss level until in is wet sanded and buffed, then it will be at 100% gloss and as smooth as glass, is that what should be done on 116?, piano finish. I will grain fill , stain and tone , then  apply clear sanding sealer which will then be sanded lightly then I will clear it using  Mohawk clear instrument lacquer 4 - 5 coats , which is very durable , wet sand with 1200 grit then then polish . 10/4 will do .Thanks
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1092 online users. [Complete List]
» 3 Member(s) | 1089 Guest(s)
