  • 1 Vote(s) - 5 Average
Mikes 16B, Not Sams
#31
Har Har Har...
Anyway, on another note.
Which one is it? Icon_lol
Kirk
Like I said....Ron is the expert. Unless someome else knows for sure.
If there is a decal. Which I think should be there.
#33
Kirk, are you using the veneer repair method where you tightly clamp a slightly oversize piece of veneer and then sand off the excess?
I think Kirk at some point described his method and it was different. The only oversize is the one outside the external wall (bezel) contour, unless you mean this oversize.
#35
Yes,
I am trying this method since it is the face of the radio. If it works well, good!
If not , it is Mikes radio so what the hockey stix do I care!
Kirk
Please take some pictures before the sanding; that's a technique I've been wanting to try.
Will do!
Kirk
Unclamped, sanded with block, and they look pretty darn good!
Toner will hide all the little imperfections.
A few more repairs and the face is DONE!
Here are the pics:
Very nice Icon_thumbup
Good work Kirk!! Very time cosuming I would think. I dont have the paients for that I do not think.
#41
Almost done with the face.
Gluing number 5 today and a last one tomorrow if I have time.
It looks so....helpless Icon_sad
#43
Face is done and stripped.
The stripping was a pain. For some reason the thinner was not working.
Had to sand most of it off.
Next is to re-attach the arch to the front and then try to repair all the veneer and the gouges and the punctures.
Any ideas on those?
I will try water and the heat gun first to see if I can get any to raise.
Here she is now.
Looks like new. New unpainted IKEA furniture Icon_smile
#45
I could always paint it. That would make the repairs easier. Could use wood filler all over and give it a nice white and black lacquer finish.....
Should I? could I? Would I?
Ok back to work, Icon_rolleyes
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
