Philco 70 detector coil
I'm in need of a detector coil for my 70. The schematic calls it first detector transformer. Philco part number 03083. Can anybody point me in the right direction. Thanks!!
I think you may have a hard time finding one of those, unless you can find someone parting out a 70. And if you did find one, it would likely be open or fail very soon. This is a common problem. Usually though, it is the primary that is open due to corrosion and resulting in no plate voltage to the #24 RF tube. This coil can be rewound with some dexterity. See the information on this page. http://www.philcorepairbench.com/tips/svctip36.htm
If you decide not to rewind the coil, I think Ron still does these. See this page. http://www.philcoradio.com/rre/rewind.htm
Good luck with it.
Regards,
Ed
Thanks for the help. I located one at http://www.oldradioparts.com
yesterdaysradios Wrote:Thanks for the help. I located one at http://www.oldradioparts.com
After a few months weeks or days, it may go bad as well. These coil are notorious for corrosion. You'd be better served rewinding it, or having Ron rewind it. The fee is small, and you get piece of mind of not having to work on it twice.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I'll probably get Ron to rewind the old one. Then I'll have one on standby.
identify very thin wire for replacement on 37-640
Thanks so much for your help!  I really could not have gotten this far without the kindness of you and other members.  T...georgetownjohn — 11:50 AM
Philco 38-7 Oscillation
Will do, thank you.tludka — 10:26 AM
As to your oscillation issue I would align the IF transformers. That may solve the problem. You also would want to check...Radioroslyn — 10:22 AM
Philco 38-7 Speaker
Thank you, I will check this out, I do have some shields I can place around the specific tubes. I searched the four que...tludka — 10:18 AM
Philco 38-7 Speaker
Also, check if any wires going to Grid Caps of the tubes that are supposed to be INSIDE of their respective shields (if ...morzh — 09:54 AM
Usually in this forum, when we discuss a radio, we do not multiply threads. You already have a thread on this. If you wa...morzh — 09:27 AM
You can possibly use a heatshrink tubing. If you decide to replace the wire, anything gauge 24, 300V rated will do (it ...morzh — 09:25 AM
Happy Thanksgiving,  I have attche a photo of a very thin wire with black plastic-looking insulation(some of it has com...georgetownjohn — 09:14 AM
Philco 60 Squealing
I got my signal tracer out to see if I could tell at what stage the squeal was coming from. It is present on the plate o...dconant — 09:07 AM
Philco 16B Parts
The 16B's in the tombstone cabinet sport a 10 1/2" spkr vs the older cathedral sets which uses an 8". The p/p ...Radioroslyn — 12:58 AM
There are currently 2513 online users. [Complete List]
» 2 Member(s) | 2511 Guest(s)
