610B Cabinet
When I brought this 610B home I posted a couple pics .  Now that I've finished the chassis (which went smoothly and has better reception than anything else I've worked on so far) I started cleaning up the cabinet.  I thought this was an original finish until I looked a little closer.  Now I'm thinking it may be the original finish with some extra lacquer or shellac added....  Here's a closer look at the side where it sure looks like someone added something to the finish ...or did they sometimes come from the factory with drips?  There are also some very dark finish areas and much lighter areas like something was stripped but not completely?  Thoughts?
[Image: https://www.dropbox.com/s/0mmmsrxbxy1tnf....jpg?raw=1]
Sorry Bob, but that is either a very poor refinish, or as you suspect someone slopped on some shellac or something; you don't see drips and runs like that from the factory.   If it is just shellack you can try some denatured alcohol to remove shellac without damaging any original lacquer underneath.  Unfortunately judging from the dark splotches I think you'll need to do a strip and refinish.  The good news is the cabinet looks pretty solid so it should be fairly easy unless that is polyurethane on there. Good luck!
That's what I was think John, thanks!  I'm going to go ahead and strip it.  I really like this set.  The cabinet is indeed very solid and should come out looking nice.  I think the grill cloth may be original, its in decent shape...what do you think??
[Image: https://www.dropbox.com/s/74vvkpicik4l1p....jpg?raw=1]
Yes, that is original cloth. Icon_smile
Thanks Ron! It will go right back into the set. Icon_thumbup
That is just fowl!
Who the hockey stix would do that! Grrrrrr
Kirk
Well the set was with the same owner since the 40s so I suspect that it was just an attempt to keep the set looking good. I think its a pretty old refinish or "finish freshener".
I was finally able to get back to the 610B cabinet.  I had it stripped, toned and lacquered 6 months ago but just finished the final rub out and wax.  Put the chassis back in with all new rubber mounts and original grill cloth.  We're streaming Christmas carols on it now through the SSTRAN...Ho Ho Ho....
Stripping...stripped...finished
[Image: https://www.dropbox.com/s/5vynwli76n9qzi....jpg?raw=1][Image: https://www.dropbox.com/s/qm1cna560uxqww....jpg?raw=1][Image: https://www.dropbox.com/s/kav2ne8bnxpb44....jpg?raw=1]
Beautiful job, Bob ! Congratulations. Now you can enjoy many years of music from it . Icon_clap
Hello bob
Well I did one these some years ago but mine was
painted white with latex paint and
they used a pillow case for speaker grille
They went as far as painting the knobs
I had to strip and refinish to if you look in the philco photo section you will see mine
Anyway yours looks very nice also I found out this radio sounds great
And receives stations nicely
Hey, radiorich - welcome back!! Icon_thumbup Icon_wave Icon_biggrin
And Bob - great job!! Icon_thumbup Icon_thumbup Icon_clap Icon_clap
I'm glad you gave it the original two-toning. I see so many that get refinished in a single color... Icon_thumbdown So it's always good to see them done right, like yours and Rich's. Icon_thumbup
Thanks guys, this was a fun one to do and did turn out nice.  Its been our Christmas player churning out carols from the SSTRAN. Rich, your radio was one of the example radios I used to tone mine.  The flash photo doesn't quite do it justice. I always go to Ron's photo gallery first for the best example of the radio.
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
Need to purchase Old Philco Radio Knobs
Hello Paulo , I have Philco 38-10 too that I am restoring the chassis is almost complete ! Far as my cabinet It is in ...radiorich — 09:00 PM
