My 38-10
This Beauty is on my bench right now..the tuning gang has lost it's rubber
pieces that isolate the gang from the chassis..is there available new rubber pieces,or else does someone have a good fix for this dilemma?
Am also looking for Ron's book--no can find Icon_sad Icon_confused:
The book is now out of print.
I have used large rubber grommets to repair the tuning condenser mountings in certain 1938 Philcos,and I believe yours falls into this category. Basically, when mounted, they take on an oblong appearance but do the job just fine.
Tubenutt, something I did on a Silvertone's tuning gang that was isolated from the chassis I used faucet washers that I got from the local hardware store. To isolate the post I used black shrinkable tubing then opened the hole out in the faucet washer to slip over the tubing that was now shrunk onto the mount screw shaft. I would have to look at my donor 38-2 chassis to see how they are mounted since it also has the magnetic tuning that your 37-10 has. oops I noticed it was a 38-10 and not a 37-10, no magnetic tuning on the 38-10 as far as I know.
Philco 16B Parts
I think the chassis is painted.morzh — 08:13 PM
Philco 38-2 Automatic Tuning
Honestrly, the original is quite acceptable and, it seems to me, can be cleaned.morzh — 08:11 PM
Philco 41-608 changer coupler
Mondial left a thread about remanufacturing thois type coupler.morzh — 08:09 PM
Are you talking about rewinding or rewiring? For rewiring, meaning runnin wires to the coil from other components, the ...morzh — 08:08 PM
12' Philco
I wonder who would be able to "no stoop" with this one.morzh — 08:05 PM
Hello PHORUM members, I am still working on restoration of my PHILCO 37-640.  I want to start with rewiring the IF ca...georgetownjohn — 06:32 PM
I am working on a Philco 41-608 with the gear-driven changer.  The coupling (#35-2220) between the motor assembly and th...alangard — 06:29 PM
Gilfillan Brothers Car Radio?
There is a Mission Bell model 19/19A that could be what you’re looking for, Riders vol 4. It has the tube line-up of: 0Z...Joe Rossi — 05:01 PM
Looking for verification of correct schematic.
Definitely 870044RossH — 01:12 PM
12' Philco
Wonder if the chassis was big too.daveone23 — 12:38 PM
There are currently 3815 online users. [Complete List]
» 3 Member(s) | 3812 Guest(s)
