Transitone 48 250 126
Once in a while they fall in your lap, not in mine that often. I got an email from a gentleman in NH who had found this set in a cottage he bought in 1984. He had used it and it had fallen into disrepair. It is in pretty good shape I am told and for the price of shipping, not much$ from NH, it is mine. Fellow could not bear to throw out. Fellow with the radio is a restorer, restored a WW2 training plane, a bi plane, open cockpit, they fly it now!
http://www.radiomuseum.org/r/philco_tran...250_i.html
So I hope it works out.
That's a fun set to work on, will look snazzy when you paint the cainet.
Snazzy is my goal.
I have a 48-250 and a 49-504. These sets are very common, and, since they both needed new paint jobs to conceal crack repairs, I decided to spruce mine up a bit. Not factory correct colors, of course, but I think they look decent. These two sets actually get more compliments than any other radio in my collection. Go figure.
I hope to get as nice, very sharp.
Set arrived today, in fine shape, labela intact, dial glass Ok but shows a tiny bit of flaking, original back, and service label from Carl's TV Radio Natick Ma.
A nice litttle set.
BTW Greg, what do you do? Fine steel wool, spray can paint? What Type?
Greg, Those are beauties!   Icon_thumbup
Joe
Congrats on the radio, Paul! I usually start with sandpaper, sanding with various grits getting finer each time, to get most of the old original paint off. Once it's nice and smooth, I spray it with a light grey primer. Then wet sand it, and spray with enamel paint. It takes longer to dry, but the enamel paint is more durable and more concealing than lacquer, IMO. Neither of those radios are clear coated. Just the enamel paint finish.
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
New find. 91X code 225
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
As I think more about that 150 ohm resistor that directly follows the selenium diode, I’m going to have to add some seri...klondike98 — 11:47 PM
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
