Horn speaker revitalizing
For those who have horn type speakers for their pre-1928 radios, a tiny magnet will greatly improve speaker performance.
The speakers were originally built with electrically magnetized magnets; these loose much of their magnetism over the years. By strategically placing one little modern super-magnet near the end of the original magnet, the audio output level is increased tremendously and tone is greatly improved too. It's totally non-destructive and brings the audio back to where it was originally.
A single magnet is about the size of three stacked dimes. Available at:
http://www.sciplus.com/category.cfm/subsection/11
(you will have to get an order built up to $25 here so go through the catalog).
This technique has proved excellent on Baldwin and GGG speakers; Finding the "sweet spot" yet for the Atwater Kent horns is underway. Magnets don't seem to do anything for coned speakers- so far.
Pete AI2V
That site is addicting. After a half hour I have found 8 items I gotta have and am seriously yearning
for the electric fly swatter.
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
There are currently 2038 online users. [Complete List]
» 1 Member(s) | 2037 Guest(s)
