AWSOME MARCONI 136/Restored Finished
Threads: 147
City: Dallas, TX
Threads: 54
Don't try stripping that escutcheon Fred, it has a faux finish on top of it, just clean it with Gojo, touch it up, and maybe clear coat over it with lacquer if you need to, not sure about the one for the pushbuttons. I don't know what to suggest with the Marconi decal, I'm not sure if Radio Daze carries those or not, I'm guessing that they don't and I don't know who else would make them. You may have to strip around it very carefully if you want to preserve it, then lightly sand it and clear coat over it.
With regard to the electrical end, these sets usually have a pair of bias cells under the chassis, so you may have to figure out a substitute, or make circuit modifications to get that extra -1.5 volt bias. I'm not sure about this model but I have a Marconi model 157, and it has some rubber wiring, including on the power transformer. The speaker was made by Utah I believe, in spite of the decal, Marconi did not manufacture their own speakers, neither did Rogers for that matter.
(This post was last modified: 05-12-2015, 02:05 AM by Arran.)
Threads: 147
City: Dallas, TX
Thanks Arran for the heads up , I did notice the escution was photo finish  never seen that before on parts and very happy that nothing is wrong with to speak off. I can make a decal here at home if I have to with photo shop on my computer using decal paper. The escution isn't warped in any way must be made out of baklite. Dick Morgan will supervise and direct me on all electrical work. He is a master and is handing down what he can to help me restore my radios
Threads: 105
City: Calgary, AB, CA
Since I live in Canada, I think you should send me that radio.. I have some Marconies , but the model 136/37 is a very nice one. The wood in the cabinets on those is very nice.. Fred, if You need the schematics for it , I have the Marconi book, which also has the dial string drawing and cap values. The radio takes a 6u5 eye tube and there is a bias cell for the grid of the 6f6.
I have always used a AG 13 1.5 volt battery for the bias cell.
show us photos after the cabinet is done..
Dan in Calgary...
Living in Calgary Alberta
Threads: 147
City: Dallas, TX
Threads: 22
City: Waxahachie, TX
Threads: 147
City: Dallas, TX
(05-16-2015, 11:12 PM)Crist Rigotti Wrote: Very nice Fred!
Tank u / Hay Crist, good seeing ya again today at swap meet , hay take a look at my favorite Philco that I restored awhile back, it is awesome and I still have it in my collection . Go to search on this website and look up 23x and you will see the pictures of it, it is a very rare set. Don,t fall down when you see it.
(This post was last modified: 05-17-2015, 12:04 AM by Fred Taylor.)
Threads: 22
(05-16-2015, 11:35 PM)Fred Taylor Wrote: (05-16-2015, 11:12 PM)Crist Rigotti Wrote: Very nice Fred!
Nice seeing you too!
You sure can find some unbelievable radios! That 23X is sweeeet!
Crist
Thank you Rodb and Gary for helping with clarification on these capacitors. Other than the Tiny 630volt one I'm not sure...osanders0311 — 10:17 PM |
Hello All;
I found the CMB41L down in the basement, it is definitely a 1950-51 model, the capacitors have date codes ...Arran — 07:48 PM |
Hi, all the caps I order, other than the electrolytics, are of the 630V rating. No worries on it being too high, and no ...gary rabbitt — 05:46 PM |
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
There are currently 1279 online users. [Complete List] » 1 Member(s) | 1278 Guest(s)
