60MB cabinet needs some love
Here's the 60MB cabinet that goes with the chassis from the earlier electronic restoration thread.  At first seemed to be in reasonable shape...you know, the usual dirty, a few dings and scratches with some paint splats on the top but as I looked closer there was lots of veneer that was just about ready to fall off on the grill area, along some of the edges and portions of the old plywood were separating.  Some gluing was needed to stabilize things before further cleaning and stripping.
[Image: https://www.dropbox.com/s/3pwdkrtl8vz86d....jpg?raw=1] [Image: https://www.dropbox.com/s/ag1669ua10aq02....jpg?raw=1]
[Image: https://www.dropbox.com/s/bx9kl5jjzstpni....jpg?raw=1]  [Image: https://www.dropbox.com/s/gt9ztskoecelxn....jpg?raw=1]
[Image: https://www.dropbox.com/s/snfltx3fmf350r....jpg?raw=1]
good luck with it bob Icon_thumbup
Here's a closer view of the surface before stripping.  Then, since its still a bit cold to be outside stripping with lacquer thinner, I used Citristrip followed by a wipedown with lacquer thinner to get the last residue off.  One last sliver of veneer to glue down  Icon_smile
[Image: https://www.dropbox.com/s/0cypszcaflypp3....jpg?raw=1][Image: https://www.dropbox.com/s/7pgn45p49fsyxy....jpg?raw=1]
Looks great so far. That's exactly the point when a cabinet becomes "ours". All repaired and stripped etc. Ill bet that front veneer looks good when you wipe it down with paint thinner..fun to get a tease like that cause it hints at what it will look like once grainfilled and clearcoated.
Wanna try your hand on this one? Icon_lol
The guy who told me about the 69 radios really wants it so I said ok but sheesh, the colors!
Looking good!
Kirk
thanks Jim, yep I wiped it down and it looks nice. Uhhh...Kirk....gee....thanks...no.
Actually, it will probably clean up well unless they did something nasty to the veneer first.
(03-28-2015, 01:47 PM)klondike98 Wrote:  thanks Jim, yep I wiped it down and it looks nice.  Uhhh...Kirk....gee....thanks...no.
 There is always the chance of that with some cabinets, I've had that happen once with one of my Canadian G.E KL500s, but mostly it's just a slacker's way of covering up a failing lacquer finish or "freshening" up the look.
With the warmer weather its been time to work on this cabinet again.  Did some grain filling using Timbermate (walnut color).  Its water soluble, so easy to mix up a slurry and spread it on, scrape it off and then lightly sand.
[Image: https://www.dropbox.com/s/4318se5iq2qehj....jpg?raw=1]
Toned the cabinet with Mohawk medium brown walnut ultra classic and the trim with black lacquer.  Unfortunately when I pulled some of the tape up after the black lacquer application some of the veneer came up.  Fortunately I was able to glue it back down without too much difficulty.
[Image: https://www.dropbox.com/s/mhq6rer99lx5qt....jpg?raw=1]
I think I've got the final gloss lacquer layer down now and will paint the edges of the grill cutouts with a flat black acrylic.  The sunlight gives it a little more red color than what you see indoors.  Final sand and rub out in a few weeks.
[Image: https://www.dropbox.com/s/ihej21mq9lw14t....jpg?raw=1]
Nice one!
bob
very nice job  Icon_clap Icon_clap Icon_thumbup
sam
Man, that's purdy. Icon_thumbup Icon_clap
OK..to finish this thread out..here's an indoor photo of the cabinet with the new grill cloth and radio installed.  Not perfect but a long way from the starting point  Icon_smile  .
[Image: https://www.dropbox.com/s/lsjwx5zr86t8u0....jpg?raw=1] [Image: https://www.dropbox.com/s/3pwdkrtl8vz86d....jpg?raw=1]
bob
looks great to me Icon_clap Icon_clap Icon_thumbup
sam
Grundig 5088
Grundig 5088
