Radiobar Chassis Model ?
I just picked up a Radiobar and I'm curious as to which Philco chassis I have.  It's a 6-tube unit but the model number is worn off the sticker.  I can still read Code 121.  Here are some pics.  Any help would be greatly appreciated.
Craig R.
Most likely 620. Could be a 625, but only if it has the shadow mask behind the dial that moves when you change the band switch (and yours does not appear to have that). If no shadow mask, then definitely 620.
Thanks, Ron!  Much appreciated!
Craig R.
Just curious... which cabinet did you score? I've always had a thing for Radiobars, not that I'll ever be able to afford one for what they go for on the West Coast...
(07-16-2015, 09:03 AM)DeckApe Wrote:  Just curious... which cabinet did you score?  I've always had a thing for Radiobars, not that I'll ever be able to afford one for what they go for on the West Coast...
This was sitting in the back of a large truck at the flea market.  Owner was just getting ready to turn it and open the top so people could see it.
Craig R.
Oooh, nice. In pretty spiffy condition, too. I think I personally would live with the wear. Icon_smile
It mostly needs a good cleaning and the black trim area redone.  Top could use some refurbishing also.  The inside chromed areas are really nice as is the mirror.  Cabinet is solid.  Veneer is also in very good condition.  As for the glassware, I don't think I will try and piece together an original set.  I would just like to find a complete, vintage bar ware set that looks somewhat similar to the originals just to fill the holes.  Any recommendations?
Craig R.
Hi Arran ,  Thanks for your help with this radio.And especial thanks for letting me know to look it up under United Ame...Antipodal — 04:32 AM
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
