Philco 19-126 tone control
Hi Folks.  I got my 19 electronically restored but I have one little hiccup.  The tone control is a 4 position switch that is coupled between the output tube and the volume control tap.  Now position 1,2 and 4 are fine but in position 3 I get a nasty squeal when the volume is up past about one third. Has anyone else experienced this?
Happiness is a warm glowing radio!
Seem like the .006 inside 33 isn't doing it's job. Check it or you can connect a .001-.005 across it this should take care of the squeal. You could try swapping the 42 and the 75 with know good ones that may do it too.
Thanks. I will look into it. I replaced all the caps but I may have miswired that one... It is such a bear to remove that control!
I'd just check wiring on the switch wouldn't necessarily take it out to do it.
I did just that, Terry. Thanks. I disconnected the wire from the plate of the 42 going to the tone control, and put an .005 in its place. Now the radio seems to work fine!!
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 750 online users. [Complete List]
» 1 Member(s) | 749 Guest(s)
