Philco 19-126 tone control
Hi Folks.  I got my 19 electronically restored but I have one little hiccup.  The tone control is a 4 position switch that is coupled between the output tube and the volume control tap.  Now position 1,2 and 4 are fine but in position 3 I get a nasty squeal when the volume is up past about one third. Has anyone else experienced this?
Happiness is a warm glowing radio!
Seem like the .006 inside 33 isn't doing it's job. Check it or you can connect a .001-.005 across it this should take care of the squeal. You could try swapping the 42 and the 75 with know good ones that may do it too.
Thanks. I will look into it. I replaced all the caps but I may have miswired that one... It is such a bear to remove that control!
I'd just check wiring on the switch wouldn't necessarily take it out to do it.
I did just that, Terry. Thanks. I disconnected the wire from the plate of the 42 going to the tone control, and put an .005 in its place. Now the radio seems to work fine!!
