Please ID this PHILCO chassis
Threads: 147
City: Dallas, TX
Threads: 71
City: Linn Creek, MO
The is fairly rare. Most people that could afford a 17 would spend just a little bit more and buy the 16 with several short wave bands. The 17 was available in cathedral, a chair side and a couple of console versions.
M R Radios C M Tubes
Threads: 147
City: Dallas, TX
(07-22-2015, 11:40 PM)Steve Davis Wrote: The is fairly rare. Most people that could afford a 17 would spend just a little bit more and buy the 16 with several short wave bands. The 17 was available in cathedral, a chair side and a couple of console versions.
Steve Thanks Steve,
Threads: 275
City: Wilsonville
State, Province, Country: OR
Threads: 147
City: Dallas, TX
Thanks you guys, I will ask Dick want he wants for it, if transformer is good 50$, would that be an insult? He,s getting rid of a bunch of stuff and that chassis. I will need to find a 91 cathedral cabinet, speaker, I have the nobs and dial bezel.
Threads: 71
A 91B cabinet is too small. The 17B cabinet is about one half inch wider than the 91B cabinet. The 17 chassis might actually slide into a 91 cabinet but it would block the ventilation holes in the end of the chassis. Also, the 17 cabinet has ventilation holes drilled in the bottom. The best option might be a reproduction cabinet.
Threads: 92
City: Clayton, NC
Steve- do you think you could make a late model 14 control panel for my early model 91 cabinet? I have a strong-playing late model 14 chassis I would like to install in it.
Threads: 71
I don't have a pattern but can probably figure something out.
If the "late model" 14 in question is the type with the three lower knobs spread apart, then it would be the same as the 18B panel and very similar to the 17B panel.
Threads: 92
City: Clayton, NC
Threads: 71
Fred, the speaker you for the 17B is a K-17
Tom, you're very kind, thank you.
Threads: 147
City: Dallas, TX
(07-23-2015, 08:56 AM)Steve Davis Wrote: A 91B cabinet is too small. The 17B cabinet is about one half inch wider than the 91B cabinet. The 17 chassis might actually slide into a 91 cabinet but it would block the ventilation holes in the end of the chassis. Also, the 17 cabinet has ventilation holes drilled in the bottom. The best option might be a reproduction cabinet.
Thanks Steve for info, can you make one for me? what,s the damage$ on a new one from you unfinished?
Threads: 54
(07-23-2015, 08:33 AM)Frederick w. Taylor Wrote: Thanks you guys, I will ask Dick want he wants for it, if transformer is good 50$, would that be an insult? He,s getting rid of a bunch of stuff and that chassis. I will need to find a 91 cathedral cabinet, speaker, I have the nobs and dial bezel. Fred
If anything $50 is too much for it, it may be in the ballpark if the matching speaker is with it and in good shape. Model 17s may be fairly rare but then again how much demand is there for a chassis from one? If you go to the swap meets there are always hoards of empty cabinets and hoards of orphaned chassis about, basically from people like your friend. This is part of what pisses me off with these donkeys who gut complete radios to turn them into guitar amps, computer cabinets, and other harebrained projects.
...I have two or three orphan 17 console chassis...
Thank you morzh, that is exactly what I was looking for. Now , is there some where that shows pinouts for Philco power ...Jim Dutridge — 11:37 AM |
Thanks for your help Michael. In fact, this video is only an intermediate result. Later I had to apply another tinting l...RadioSvit — 09:01 AM |
Great job on the cabinet.
PS. In the US notation, "kenotron" refers to specific type of tubes; we call re...morzh — 08:24 AM |
This document has at least some tables of models and parts used.
Example: Choke 32-7572, used in 604 radio.
Search f...morzh — 08:19 AM |
I also checked all the radio tubes on my Hickok 530 tube tester. The 5Z3 kenotron turned out to be faulty, all the other...RadioSvit — 08:02 AM |
Well... While the varnish is drying up, I started repairing the chassis...
Of course I started by replacing the pa...RadioSvit — 07:12 AM |
Hello Martin,
Welcome aboard our little community what great Model 38-7
Sincerely Richardradiorich — 12:30 AM |
Welcome to the Phorum Martin.
I count about 9 paper caps, the 3 electrolytic caps and 2-Y2 safety caps to replace th...RodB — 09:44 PM |
Jim,
We have this index put together by Dale Cook but I don't think that is quite what you are looking for.
The Parts...klondike98 — 09:37 PM |
Yep the dim bulb test is OK but I'd definitely replace all those electrolytics before I did it. Since those #47 conden...klondike98 — 09:18 PM |
There are currently 1089 online users. [Complete List] » 2 Member(s) | 1087 Guest(s)
