Threads: 367
City: Dover, OH
After a couple weeks of no responses to my emails and phone calls, I decided to stop in personally at the shop in Barberton to see if the Philco A-361 console was still there. Turns out the shop had changed hands and the Philco was still there and priced $50 lower than it had been in the ad! So, I snagged a nice Philco A-361 console that seems to check out on transformer and even picks up a few stations when brought up on reduced power. Shows plenty of good signs. Cabinet does have a few blemishes, including a crack above the dial that seems caused by poor wood. Speaker looks good except one spot I repaired at the edge of the cone. Actually looked like the paper was simply too thin and wore away over the years. I think with a recap, and a good realignment, this will be a nice set from a unique time in radio history. Chuck: Do you have any paper work on this model I can order?
P.S. The one picture came out dark and grainy, I don't know why. Radio looks better than that!
Threads: 242
City: West Bend, Wisconsin
Neat "car radio in a console cabinet" set. I've often wondered if the knobs on these were later used on the 1201's and hippo models after the war? I've never seen a real clear picture of them, but they do appear to be similar.
Threads: 367
City: Dover, OH
While the knobs look a bit like the ones on the Hippo, they are different animals. There is a plastic knob mounted in front of a metal ring. The ring behind the volume knob is actually a tone control while the one behind the tuning knob is just decoration. I've noticed that the tuning knob has shrunk and warped, causing it to be hard to get off the shaft. Also, the shaft rusted some where it made contact with the plastic while the volume knob and shaft are just fine. Not sure what plastic they used, but it is actually transluscent as light will shine through it!
Threads: 242
Interesting. Thanks for clearing that up. Looking forward to seeing your progress as you restore this beauty!
Threads: 27
City: Petaluma, CA
Be careful when you get around to cleaning the dial lens. The numbering and the lines on the back side will come off very easily. I learned the hard way.
Craig R.
Threads: 367
City: Dover, OH
Thanks for the advice. The dial lens looks decent, so I will just let it be.
Threads: 2
City: Eugene, OR
I like it! That's definitely a conversation piece, but it's also a very nice looking radio! Congrats and enjoy the restoration!
Threads: 367
City: Dover, OH
More good news with this radio. Tested the tubes and all were very good except the 7B8 tube which read a bit weak. Luckily, I had a better 'Genuine Philco' 7B8 in my stash to swap into the radio. I must say, these loktals are fairly durable tubes overall. Both dial bulbs are blown, but everything else checks out so far. One question I have is cleaning the slug tuners on these units. As I said earlier, it will tune some stations on low power, but it's VERY touchy and I am suspecting dirt and crap in the tuner. Is there a safe way to clean these or should I simply use compressed air to get the worst of the gunk out of the tuning coils and slugs?
Threads: 4
City: Marshall MN
Are these rare? There is one at an antique shop that has been there for years.
Here's another fine mess you have gotten me into. Oliver Norville Hardy.
Threads: 54
(07-28-2015, 10:01 AM)Scottb Wrote: Are these rare? There is one at an antique shop that has been there for years.
Not really, they seem to turn up on a fairly regular basis, what makes them interesting is the history behind them. There is another similar set that Philco made out of a MoPar car radio, in a chairside or coffee table style cabinet. Both are somewhat on the crude side since Philco was attempting to use up left over Ford and Chrysler car radios by converting them to AC operation.
PT 6 chassis screws size???
Have this done except for missing chassis screws.
It looks like 1 inch 6/32 sheet metal screw may work but can anyone s...bridkarl — 10:32 PM |
Hello Stormlord,
Well done on rewinding that coil it turned fairly good for your first one.
Sincerely Richardradiorich — 09:12 PM |
Well here it is. It ain't pretty, but hopefully it'll work.
I checked it with my DMM on continuity and it keeps and r...Stormlord5500 — 08:56 PM |
Yes, 57 is an electrolytic cap that should be 12 mfd 400 volts according to the parts list from the Phorum library schem...RodB — 06:01 PM |
Looks like if I am reading it correctly it looks like the silver capacitor#57 that appears to be a replacement is of a l...osanders0311 — 05:09 PM |
Thanks Arran. Yeah this plastic is pretty thin. It's a little thinner than the original stuff. It kinda reminds me of p...Stormlord5500 — 04:37 PM |
The equivalent of one short turn is basically the same as that of a shorted load.
If it is the primary's turn, then the ...morzh — 03:53 PM |
I've never had an output transformer become shorted, the failure mode is usually an open primary, or in a center tapped ...Arran — 03:52 PM |
As long as the plastic sheeting isn't too thick, I think that the thickness of photographic film would be just about rig...Arran — 03:19 PM |
Well why not! :lol:Stormlord5500 — 03:14 PM |
There are currently 953 online users. [Complete List] » 2 Member(s) | 951 Guest(s)
