53-960 questions
I have a Philco 53 960 that does not work (of course). I found Ron Ramirez's posts on his 53  960 and following his instructions and photos I replaced the bumblebee caps and the 51 a, b, and c electrolytic capacitors.  When I power up, the 330 ohm 3 watt voltage divider resister gets so hot it begins to smoke. What is wrong?
(07-28-2015, 05:18 PM)doc612 Wrote:  I have a Philco 53 960 that does not work (of course). I found Ron Ramirez's posts on his 53  960 and following his instructions and photos I replaced the bumblebee caps and the 51 a, b, and c electrolytic capacitors.  When I power up, the 330 ohm 3 watt voltage divider resister gets so hot it begins to smoke. What is wrong?
If you mean R-13 Check the polarity of your filter caps if you have one in backwards that will do it.
Well, I checked the filter caps- polarity is correct so I powered up again and this time no smoke! I unplugged and finished replacing the paper caps and fired it up again. There are 3 AM stations within 3 miles of me and I couldn't pick them up...but at about 1100 I picked up ESPN radio from where I have no idea. Not from around here. It was very quiet and static filled and they never gave call letters or city. And on the second SW band I heard a preacher- again, faintly. What the heck is wrong now?
Recheck your paper caps wiring to make sure they are where they are they are suppose to be. If miss wired  you maybe bypassing the signal to ground. Clean the band switch. Make sure that it is good and dry before applying power, don't want to set it ablaze.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1022 online users. [Complete List]
» 1 Member(s) | 1021 Guest(s)
