Philco 84 Restore
I am just finishing up a restore of a Philco 84 cathedral.  I had to rewind the primaries on the antenna and oscillator coils.  I replaced all the capacitors. I also replaced all the dogbone resistors. I have adjusted the regeneration control, and peaked the IF capacitors.  It is playing with pretty good volume with only an 8 ft. piece of antenna wire.
I need to still make the 2 meg ohm resistor change from the service tip in the IF transformer to see if it plays even better.
Question...I noticed that someone had removed the "gimmick" capacitor (#3) so I replaced it.  It seemed to make no difference.  What exactly is the capacitor doing?  Coupling a little extra signal from the antenna to the oscillator?
Why would it seem to not be needed?
Mark K8KZ
Hi Mark.  I have that same gimmick cap in my 41-280.  My guess is it works as a filter.  I don't know exactly how, but others on this site can offer more info than I can.  All I know is that I was told to keep it in the circuit or you can pick up a lot of "white" noise.  Take care, Gary
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 774 online users. [Complete List]
» 1 Member(s) | 773 Guest(s)
